Old 01-15-2007, 07:38 PM
ec300 2t ec300 2t is offline
Angry front brake howl
I have a front brake problem I hope you guys can give me some suggestions on. I have a 2002 EC300 that has a front brake howl(horrible noise especially on long downhills) that has been an issue since the machine was new. I have chamfered the leading edge of the pads, sanded the pads, checked the pins,bolts etc. None of this has made a difference. I am out of ideas short of trying different pads or rotor but I don't want to spend money if it won't solve the problem. It of course has Nissin brakes. Any help would be appreciated.
Old 01-15-2007, 07:57 PM
Boomhauer's Avatar
Boomhauer Boomhauer is offline
A friend of mine had the same problem with his 200. He ended up de-glazing the rotor with some sand paper and that corrected the problem.
You might want to try a new rotor if this does not help your problem.
Bikeless for Now
Thanks to Smith's Powersports 724-899-3375
www.smithspowersports.com
Old 01-27-2007, 06:46 AM
Hawkeye Hawkeye is offline
My '02 300XC used to do this once every 6.4 races or so. So I just got in the habit of cleaning my discs with a clean rag and brake cleaner after each wash. You'd be amazed at the dirt that comes off. Also, many cleaning solutions used on dirt bikes leave a residue that will reduce the effectiveness of disc brakes. Clean your discs after you wash your bike - it is quick and prolongs pad life and effectiveness.
In a pinch, I have used a propane torch to burn oil out of old pads that have been contaminated from leaking fork seals. Obviously take them out of the caliper to do so, and let them cool completely before cleaning them and the disc with brake cleaner. The 100% solution is to replace the pads.
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
Old 02-12-2007, 05:37 AM
bxb's Avatar
bxb bxb is offline
Clean brake pads in the dishwasher. The alkaline based detergent is brilliant.
As for the noise, go out to your car and remove one of your front brake disc pads and observe the thin piece of metal clipped onto the back. This thin bit of crap stops your brakes squealing and howling. Don't believe me? Put the pads back minus the strips and see how far you get before the cops pull you up or you die from embarrassment.
To permanantely shut the bike pads up, find some old car pads and with a grinder, tin snips and a bit of imagination, make some backing plates to clip on.
TA DA....end of problem.
Old 02-12-2007, 07:33 AM
Organic compound pads and a clean, deglazed rotor. Metallic pads tend to wear and polish the rotors faster. You said since new. Did you clean the rotors before riding the bike?
front brake crossover kai69 Enduro Other... 5 09-04-2010 04:47 PM
Front brake line? nick790 Enduro Chassis & Body 0 05-27-2009 03:50 AM
Front brake is on all the time Larsa Enduro Chassis & Body 7 11-11-2008 03:13 PM
Front Brake protection? Link General Discussions & Announcements 3 09-17-2007 07:35 AM
Front Brake Lever cladoo Enduro Chassis & Body 4 02-07-2007 08:45 AM
