Old 05-10-2014, 11:03 PM
nato nato is offline
Where can i get hold of the gaskets to space out my starter system? For the ring gear gap.
Does this rag smell like chloroform?
Old 05-12-2014, 10:43 AM
Neil E. Neil E. is offline
I don't know about the shim supply, maybe a dealer or GoFasters. First try the system with no cover gasket to see how much it changes. The best way is to tape the bendix open and feel for play at the top gear. You want a noticeable back and forth, say not exceeding 1 mm.
If it looks good this way, use silicone on the cover as your sealant. Just make sure the starter motor is relatively vertical. Keep in mind that the starter only drives the upper gear and doesn't have to be perfect. With the cover bolted on, the starter motor should lift up and down (grease the oring). As long as you have some freedom of movement, it should be OK.
2011 EC250E
Can I add a starter? Jeffm Enduro Electrical & Wiring 17 11-09-2013 07:23 PM
starter jet....where and how? mp5 Enduro Intake/Carburetion - 2 stroke 1 05-01-2013 09:13 AM
New starter kit (without subframe) MrBlah Enduro Engine - 2 stroke 0 11-03-2011 06:24 PM
Kick Starter ? rockrider1 General Discussions & Announcements 1 11-04-2010 08:49 AM
starter on 450 ec jenkitchen1006 Enduro Engine 4 stroke (including EFI & Exhaust) 3 05-21-2009 06:38 AM
