Old 11-04-2010, 11:09 AM
GasTimppa GasTimppa is offline
I did same mod as Leon Gas today, but I left rear/and brakelight AC (35w output). I can use heated grips with that AC output as well. Works fine.
Originally Posted by Leon_gasgas View Post
Hi!
As I wrote yesterday I connected only the yellow wire to the "trailtech" dc reg. Today after 2 hours drive I measured the voltage at the battery with the front light on. It was between 14.40 to 14.75 volts max (high rpm). Pretty good and better than the 14V when I had connected both stator wires together! The battery's cycle use is between 14.40 and 15V. So the whole system is OK. I have to say that last week the trailtech helmets lights flickered sometimes. The hid headlight was ok. I am sure that they won't flicker again! Steve the measurements you gave are really off. Is it a gasgas 2K3 or KTM 2K3?
Many Thanks you put here the link from bajadesigns with a clear diagram on how to go hid without modifying the stator!
Leon
There is no such thing as bad weather! Only riding gear is improper or insufficient
When it hurts you know you're allive!
Gas Gas EC 300 Factory Racing 2012
- Ohlins TTX both front and rear
- Rekluse Core EXP 2.0 + Rekluse clutch basket
- Scalvini full exhaust system
- S3 Head
- Trusty adjustable PV cover
That was ultimate setup for me...
Now trying something else for a while...
Old 11-04-2010, 12:17 PM
moto9's Avatar
moto9 moto9 is offline
Great thread, someone should post some pics showing the process.
And it should be a sticky...electrical is probably the most confusing aspect of a motorcycle.
I finished wiring my 08 300 up...I went AC to run the headlight, tail light and blinkers...I didn't want to add a battery.
Old 04-24-2011, 11:00 PM
Magellan Magellan is offline
slocal,
You are getting confused becaue you are looking at two options. The BajaDesigns PDF is basically showing you one option that is what I said about an isolated DC system, that retains the stator ground. The other is the floating AC grounded DC method. Decide what you want to do and follow one path.
Can someone give the pros and cons of these two approaches. I have an 04 EC300 with the full OEM light kit. I would like to add a battery so I could have lights if the engine dies. I've done some night enduros, and it's dark in the woods. Also, I'm going to start riding my bike to work, and for safety would like the lights to work without the engine running.
I'll probably just stick with the stock headlight, but do like the option of running LEDs, which I believe require DC.
Finally, I have a helmet light that will run off either, but if there is an advantage to running it off AC (more efficient?), then if having an isolated DC system allows that, it may be the route I want to go.
Thanks,
MCP
James
2004 EC300 -- LTR Stuff, RB Designs Carb Mod
2016 Africa Twin
1975 Honda CB400 F1 (X2, projects)
2019 RE 650INT
1982 KDX80
2017 KAW EX300
1982 XL500R
2015 HUSKY FE501S
1972 HON CB175
Old 04-25-2011, 07:37 AM
GMP's Avatar
GMP GMP is offline
It has been beaten to death in this thread and others. Please search and read. If then you still do not undestand something I will be happy to help you.
Old 04-25-2011, 07:46 AM
johnm johnm is offline
Work required is similar but different. The floating AC requires the generator removing and modifying. This allows the existing grounds for lights to remain in place. Floating the DC system, does not need any mods to the generator side of things. But the whole DC system needs the earths tying back to the battery or capacitor and off the frame.
For me floating the DC is the best solution. Hence writing an install how to (now a sticky)
If you want lights that are bright all the time, at idle and full throttle, DC is the only way to go. You choose floating AC or floating DC, which ever you are most comfortable with with - either will work.
I used Trailtech battery (under side panel beside air filter) and Trailtech rectifier/regulator and installed a 65w full size halogen headlamp (Ricky Stator) and led flashers and tail light.
Old 04-25-2011, 11:16 PM
Having read this thread and many others, I think I have a good understanding of what needs to be done in each scenario, but am still not sure how to decide what path to take.
I will take a stab at answering my own question, and maybe someone can confirm or deny what I say.
Option 1: Float the AC Ground
Pros: simplifies installation of any future accessories/lights since you can ground everything to the frame.
Consistent light output (no drop at idle)
Cons: Requires modification to the stator wiring itself
Option 2: Isolate the DC Ground
Pros: No mods to the stator wiring
Can still use AC if you want (any practical advantage to this?)
Cons: Need to maintain separate ground path for all DC components
Risk of damaging something if you short to the frame?
What I feel is missing from my list:
Is DC less efficient than AC (maybe a reason to keep AC power available?)
Is there a cost difference in regulators for either option?
I think both options can utilize a battery, so no difference there.
Does that about cover it?
Thanks,
MCP
James
2016 Africa Twin
2019 RE 650INT
1982 KDX80
2017 KAW EX300
1982 XL500R
2015 HUSKY FE501S
1972 HON CB175
Old 04-26-2011, 09:43 AM
GMP's Avatar
GMP GMP is offline
James,
It depends on what you want to run on DC. If your intent is a full blown dual sport type setup with battery then the stator mod and DC grounded frame may be the way to go. If you just want to add better lighting like LED or HID then an isolated DC system just for the lights is cleaner.
The 10W LED lights use an internal driver and require 9 to 30 VDC, HID similar but higher power requirements. Two of these lights on my Ducati Hypermotard make the 55W halogen headlight irrelavant. They are also small and totally bulletproof, perfect for rugged offroad use. Being only 20w total (3.4A @ 12V) its easy to get a lot of light out of the stock stator. I will be trying this myself, to run a pair of VisionX LED driving lights on an isolated DC system from a 2K-2 ignition. Lights, rectifier/regulator, capacitor, switch and connector, no battery needed. Everything will be mounted to the back of a number plate.
Thread Tools
Display Modes
2005 EC300 vs 2007 EC300 alecsstefan Enduro Engine - 2 stroke 19 01-22-2010 01:40 AM
