Old 08-28-2016, 10:07 PM
Zman's Avatar
Zman Zman is offline
Sounds like your regulator is not working correctly. Make sure it is grounded well otherwise your voltage may be higher than normal.
Old 08-29-2016, 01:14 AM
Originally Posted by muddertrucker View Post
Have you found a solution to this problem?
I'm getting over 16 volts on mine. I bought a led h4 bulb and it shuts off when i rev the engine. The regular h4 has not blown yet but i blew 3 small led bulbs.
My voltage regulator is an aftermarket one and was installed in april.
Is it a 2013 without a battery/e-start?
I still haven't resolved mine.
Old 08-29-2016, 06:23 PM
GGRider01 GGRider01 is offline
I thought I was toasting regulators for some time now.. Maybe they're just overpriced junk electronics.
Old 09-02-2016, 02:01 PM
Fleetch's Avatar
Fleetch Fleetch is offline
Originally Posted by Neil E. View Post
I don't know what to offer at this point. Maybe the next step is to put in an aftermarket full wave rectifier and unground all of the lighting. The stator, CDI and coil remain grounded as normal. The old regulator is removed.
Input to the new reg/rect is yellow and ground. Output from the reg/rect is DC on red and blue wires. Red is used as positive and goes to the headlight switch. From there power goes to the headlight as normal.
The original ground wires at the headlight and tail light are disconnected and moved to the new blue wire. This means the lighting is not frame/chassis grounded. It only gets DC negative via the reg/rect blue wire (we are isolating/floating the reg/rect output by doing this).
The tail light can be connected to the new red all the time. The brake light switch will be connected to the new red wire and the switch output will be connected to the brake light filament.
No battery is needed. If a battery is added, then white and ground can power the reg/rect so the voltage is a bit higher and will charge the battery.
Just to recap, the stator has three connections: engine/frame ground plus yellow OR white wire. Yellow = most of the windings, white = all of the windings.
Does anyone know an aftermarket full wave rectifier that can be used?
Old 09-02-2016, 02:12 PM
(F5)'s Avatar
(F5) (F5) is offline
I used a cheapo 4wire scooter one from Aliexpress on my racebike fitted with a CR250 iignition and it worked a treat. But Iwas running a large 25v capacitor to help smooth things out. A battery of course would be better still.
Like this. Buy a couple in case you wire it the wrong way.
http://www.aliexpress.com/item/4-Wir...2-f6c624122649
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-02-2016, 03:11 PM
Fleetch's Avatar
Is that a full wave and do you know how to connect it?
Old 09-02-2016, 10:46 PM
(F5)'s Avatar
I would think so but can'tvouch. I found a diagram for the scooter and just replicated.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
gasgasman's 2015 250R ride report gasgasman Ride Reports 7 04-02-2015 08:40 AM
Honda DI 250r for 2015! nambo-trev All Other Bikes... 3 04-01-2014 07:31 PM
Countershaft/Sprocket seal leaking on '12 250R Novascotiarider Enduro Engine - 2 stroke 14 04-19-2013 05:00 PM
'12 250R is in the house GMP General Discussions & Announcements 66 07-03-2012 11:55 AM
Gas Gas 300 Quad. Will 250r radiator fit? skoolball23 Other GasGas Bikes/Quads 2 04-26-2011 08:15 AM
