Old 09-18-2023, 08:39 AM
Gasser Nate's Avatar
Did you wash the cylinder with hot soapy water after you got it back from the platers? Sometimes they are a bit lazy and don?t wash them properly. And brake cleaner on a rag is not good enough. The hone lines it the cylinder hold a lot of microscopic honing grit etc.
Check for cleanliness with a wipe with a white rag and fresh engine oil. Should not be grey at all.
Old 09-19-2023, 01:16 PM
Dario Dario is offline
I just washed it with a rag and some brake cleaner. Put a little bit of an oil coating everywhere and put it on.
Old 09-19-2023, 01:29 PM
+1. The debris can get into the transfer ports also, so clean everything well with soapy water until no residue is visible.
Tags
cylinder, piston
ec 300 cylinder problem... knutte112 Enduro Engine - 2 stroke 7 02-17-2014 11:13 AM
problem 2002 ec300 wont rev out? andy176 Enduro Engine - 2 stroke 17 10-07-2013 07:54 PM
2006 EC300 problem fury1 Enduro Engine - 2 stroke 29 06-09-2009 05:40 PM
ec300 clutch problem dirtjunky_uk Enduro Engine - 2 stroke 13 02-27-2009 08:08 AM
Gear box problem 07 ec300 peterr Enduro Engine - 2 stroke 5 02-26-2007 01:07 AM
