Old 04-04-2009, 07:13 PM
mxdj2003 mxdj2003 is offline
when you do get the old plug out shoot me an email , i make steel drain and fill plugs i get $20.00a set and that problem will never happen again
Old 10-13-2009, 04:39 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Originally Posted by jyellard View Post
I thought of trying to fish it out with another magnet in hopes that I can get the plug to line back up with the hole and grag the plug magnet with some needle nose pliers. I'll be trying this today.
I've already ordered all the gaskets I need to split the cases, as I'm really not counting on any "tricks" to work.
I'll try a few things before splitting the cases. I'll also be buying some left hand twist bits in the near future.
Thanks for the suggestions.
Did the same thing as above and luckily managed to get the bolt close to the hole, got another magnet and played around with a pair of needle nose pliers to try to get the thread lined up..... did so and then used the magnet to unwind the broken bit out.
Lucky for me it worked.
Now if I could just find the correct pitch and size of the bolt I will do a ring around tomorrow for a new one..
Anyone????
Cheers Mark
oil drain bolt crossover ? Brian VT Enduro Engine - 2 stroke 6 08-04-2009 08:11 PM
FYI, Cylinder/Case mis-matching, 3/16" off! socalscott Enduro Engine - 2 stroke 4 11-26-2008 06:44 PM
Looking for information to split case RayGas Enduro Engine - 2 stroke 2 05-26-2008 08:15 PM
Help: Case crossover question Berkyboy Enduro Engine - 2 stroke 7 11-01-2006 10:06 AM
