Old 04-22-2012, 11:15 AM
rxmx rxmx is offline
Default 2011 Engine / Frame alignment question
After 50 hours of riding I pulled my swingarm and linkage to check / grease the bearings. On reassembly, with all other engine mount bolts still tight, the rear engine "hole" doesn't line up well with the frame/swingarm/linkage (the engine sits about 1/16" low). Is this correct, ie is the frame / engine supposed to be connected with "tension", or should I relieve other frame bolt holes to remove it? Thanks for any advise.
Old 04-22-2012, 11:30 AM
Neil E. Neil E. is offline
The swingarm bolt should be the main reference. Loosen eveything else and wiggle the motor until the swingarm bolt lines up.
2011 EC250E
05 engine in a 07 frame PEB General Discussions & Announcements 3 10-18-2011 08:55 PM
airbox-reeds no longer in alignment. opinions/options please. dank Enduro Intake/Carburetion - 2 stroke 10 07-26-2010 06:29 AM
An 01 GG 300 engine in an 04 GG 200 or 300 frame? prentice Enduro Engine - 2 stroke 5 02-07-2008 12:07 PM
Engine mounts on to frame west aussie gas 450 Australia & New Zealand 3 01-28-2007 08:16 PM
engine mounts on to frame west aussie gas 450 Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-26-2006 08:59 AM
