Old 12-17-2013, 06:21 PM
thejackrabbit thejackrabbit is offline
Default how to tell what size A,B,C,D?
are there any marks on the cylinder I can look for to determine if i have a A,B,C,D size cylinder?
Old 12-17-2013, 06:30 PM
JP4's Avatar
JP4 JP4 is offline
The letter is stamped on the back of the cylinder near the bottom.
Old 12-17-2013, 06:44 PM
Rick's Avatar
Rick Rick is offline
On my 99 EC200 it is marked on the back of the cylinder, just about the reed cage.
I would assume that if your asking, then yours is not marked?
Next time your due for a topend, remove the cylinder and have it measured a good shop can do that for you. I think it is check in 3 different locations of the cylinder. Based upon those numbers then you can check your piston options.
Hope that helps.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 12-17-2013, 06:46 PM
I looked all over the back and there is no mark, i was searching wiseco pistons and to me it seems like they only come in one size for my 2005 200. so does the size really matter?
Old 12-17-2013, 08:01 PM
Rick's Avatar
http://www.wossnerpistons.com/produc...ame=2+Off-road
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 12-17-2013, 08:21 PM
To answer your question, yes it matters. If it is too loose it will not perform as well as it can. If it is too tight you could have problems with seizing. Since it is a 2005 and you have it apart, I assume it has some miles on it and needs a rebuild. If you can feel any ridge at the top of the cylinder, I would get it diamond honed and measured so you don't waste money, time and HP.
GG 200 size Darkside General Discussions & Announcements 21 01-31-2012 10:57 PM
what size weight? boostedte37 General Discussions & Announcements 11 01-17-2010 06:12 PM
Bib Mousse size? gasgasman Enduro Chassis & Body 2 10-24-2008 05:08 PM
Nut Size steve Enduro Engine - 2 stroke 2 01-11-2008 10:58 AM
