Old 02-23-2015, 02:23 PM
richgilb richgilb is offline
Default Is no resistance when kicking in gear possible?
Just got a 2011 bike after my 2003 bike got nicked. I was hoping to find that the later bike would kick in gear as easily as it does in neutral, only to learn it has the same frictional resistance as my old bike had, like the clutch is only disengaging the engine about 90%. Is there anything I can do to get the clutch working like it does in just about every other bike I have owned?
2003 EC200, 2013 Husky TE310, England
Old 02-23-2015, 02:44 PM
Brian's Avatar
Brian Brian is offline
What oil are you running? I'm using Rotella T6 5W40.
I have no trouble starting in gear with the kicker or electric starter ouch the bike is warm.
2006 Gas Gas EC250
2011 Husaberg FE390
Old 02-23-2015, 04:11 PM
Neil E. Neil E. is offline
Most wet clutches have noticeable drag when disengaged.
2011 EC250E
Old 02-23-2015, 05:31 PM
(F5)'s Avatar
(F5) (F5) is offline
Adjust the lever for most pull, run a decent oil as suggested (I use Motul Expert, normal Transoil drags). Then its down to basket (inner & outer) condition. I can kick my '07 ok in gear.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 02-24-2015, 01:42 AM
I can kick it in gear ok too. But it can mean it is firmer and therefore harder in difficult positions. So I can kick it ok but not as well as when not in gear.
Oil was changed, clutch plates and basket in mint condition. Oil changed in the hydraulic line too. Thinner oil put in the gearbox.
Lever is adjusted.
I do not agree most wet clutches do this.
Can something be done with the push rod?
Old 02-24-2015, 04:15 AM
rubber Jonny rubber Jonny is offline
My 2013 gas gas still has some friction in neutral, it always has had.
Old 02-24-2015, 05:33 AM
Hopefully not from the transmission?
Old 02-24-2015, 10:14 AM
shang shang is offline
Every bike I have ever owned has had more resistance when started in gear. I'm sure it can be minimized, but your spinning clutch disks with a viscous fluid between them. Your gonna have some added drag.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 02-24-2015, 12:28 PM
(F5)'s Avatar
Try some of the recommended oils, there's lots of threads, it makes a difference. I'm not tall so it is important to me
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 02-24-2015, 03:20 PM
Leo's Avatar
Leo Leo is offline
Mine drags noticeably more with cold engine. After 10 minutes ride, this become much better.
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Wanted!! Ec200 seat, radiators, switch gear, gear lever Kendog "Wanted to Buy" & "Want To Trade" 2 10-12-2014 03:12 PM
kicking a 2T Adss General Discussions & Announcements 25 07-31-2013 11:20 AM
high rolling resistance jdosher Enduro Chassis & Body 0 02-07-2013 07:16 PM
Rock kicking... GasTimppa Injury & Recovery 12 07-13-2012 10:25 AM
Kickstart not retracting after kicking??? wence Enduro Chassis & Body 2 07-28-2010 04:49 AM
