05 FSE450 fuel light
When I bought my bike, the PO had switched back to the stock tank from the Clarke that he bought. I ran out of gas shortly after I started driving it. There was no low fuel light! Turns out when he plugged the fuel pump harness to the tank he bent one of the pins.
I straightened it out but made sure to fill up every 45 miles or less to be safe. FF to today. After unsuccessfully putting the Clarke tank back on, I have to go back to the stocker. Figuring it was a good time to check the light with no fuel in the tank, I plugged everything in and...nothing. No low fuel light. All the pins are straight. I know what color the wire is from looking in the manual, but how can I test this? check resistance in fluid and out? Bad sensor? bad light? I want to go riding with a friend (he's got DR) but I have such pitiful fuel range I want to play it safe. |
How many miles you need to go ? I could easily get 80 hard miles out of my 05 with the Clarke tank.
Dont follow me, You wont make it. |
Until the Clarke tank is repaired ( if it can be) I'm stuck with the stocker. I've never ridden up there (Northern WI) but he said the shorter trail is 25 miles. I'd hate to resort to carrying 2 liter soda bottles full of gas |
Stock tank is good for 40-45 miles.
I got the fuel light issue resolved. When swapping the bulp from the high beam to test it I found that parts of the wiring harness were mangled. Probably from rubbing, but the previous owner did a helluva number on some of the wires as well. Installed connectors and taped up bare spots on wires, everything seems fine now.
Do GasGas Supermotos not come with a low fuel light? | gomi | Enduro Electrical & Wiring | 5 | 06-19-2009 08:32 AM |
Oil light on | Oldcow | Enduro Electrical & Wiring | 0 | 05-17-2008 07:42 PM |
Fuel range and fuel light | sanderjavant | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 01-05-2008 02:35 AM |
Too Much Light !!! | FFRDave | Pictures & Videos | 0 | 11-14-2006 02:33 PM |
