Crank Case Breather Hose Question
On my 2019 300 EC I found two hoses near the cylinder. One on each side coming from the PV housings. They both were connected two the air box.
According to the race prep recommendations I removed them and plugged the hole in the intake rubber. I always find a drop of oil coming from the left hose. Sometimes it is a bit thinner and obviously mixed with water sometimes it is pure oil. I also had this on both other 300's I had but not as much as on my actual bike. Bike is new (9 hrs) and runs very well otherwise. Compression is fine too. Reason to worry? PS I cross posted my question on TT Forums as well... |
The left hose is the power valve chamber drain.
Some residue is normal. The right side vent hose- pointing up- is the transmission vent. |
Thank you GGman, could be due to the fact that I was running 40:1 the first tank for running in... So more oil than normal.
Oil is good. 40:1 -is fine and brings benefits of reducing wear for little extra expense.
I think we've once discussed oil ratios. I normally run 60:1 and even 80:1 and never had a problem.
Currently I run 50:1. |
(and that is as far as i am getting into 2t mix discussion lol)
That's true. I am mostly in the lower to mid range but on straight sections I let her rip from time to time. On the playground(s) I normally ride WOT in 5th and 6th is possible for about 5 seconds |
Routing crack case breather | okay_GG | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 05-05-2020 10:49 AM |
Crank case breather/ Oil in intake | spencergt66 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 06-10-2016 11:39 AM |
2011 EC250f manual---breather hose question | forgiven | Enduro Engine 4 stroke (including EFI & Exhaust) | 7 | 09-11-2012 05:57 AM |
Crank case interchangability | Rabbitist | Enduro Engine - 2 stroke | 5 | 09-21-2011 05:44 AM |
Crank bearing spinning in case... | CDBiker220 | Enduro Engine - 2 stroke | 8 | 02-16-2011 11:53 AM |
