Old 10-29-2013, 12:53 PM
Diggs345's Avatar
Diggs345 Diggs345 is offline
Default 2012 ohlins shock springs
Hi all
Do the springs off any other bikes fit the 2012 ohlins shock , not ttx , or is the spring specific to that shock , I'm looking for a 5.4 as iv had my forks upgraded to 4.6 .
Regards
Chris
Old 10-29-2013, 12:59 PM
twowheels's Avatar
Others are close but you're best off with the Ohlins.
PlusOnePerformance
Steven Beane #275
afterhourscycle.com
Old 10-29-2013, 01:04 PM
Diggs345's Avatar
Wow that was quick , thanks for the reply , I was just hoping a secondhand one off another bike would fit
Old 10-29-2013, 01:07 PM
nambo-trev's Avatar
What do you have right now(spring rate)? I'll have a look and see I have one ttx and one 888 but not sure which spring rates they are. Steve is right though best to go with an ohlins for perfect fit.
trevor
Old 10-29-2013, 02:39 PM
Diggs345's Avatar
It's a 5.2 on it now , thanks for your kind offer but postage to the uk would be as much as a new spring , but thanks again
Old 10-29-2013, 03:25 PM
I'd probably look at going at a 5.6 rate spring Diggs with the .46 fork. Run a little less preload and happy days. I've used 5.2, 5.4 and 5.6.
Old 10-29-2013, 04:04 PM
Diggs345's Avatar
Cheers jake , I was thinking that too but looking back at Glenn's set up he said the 5.6 was a bit too much with the 4.6 fork springs
Old 10-29-2013, 06:34 PM
There were some linkage changes in 2012 so maybe the chasis does require a softer spring. From memory I thought most of Glenns findings were reporting that the 48mm CC Zokes required much less spring than the 45mm OCs, and that the back end was quite similar.
WP Fork Springs & Ohlins Shock Spring Rick "Wanted to Buy" & "Want To Trade" 3 08-08-2013 02:31 PM
43 WP / Ohlins Springs Rick Enduro Suspension 2 07-24-2013 11:34 AM
Servicing 2012 Ohlins Shock? CDBiker220 Enduro Suspension 13 03-15-2013 08:32 AM
2012 300 - Ohlins rear shock StuJohnson Enduro Suspension 26 02-27-2013 09:07 PM
