Old 01-04-2016, 09:56 PM
GGRider01 GGRider01 is offline
Default How does the 2 wire Voltage Regulator function?
I have a quick question regarding voltage regulators. Since mine doesn't have one that I can find except under the gas tank by the yoke, which I believe is strictly for the horn (correct me if I'm wrong, please).
All the wiring diagrams I see show to splice it into the yellow off the stator and ground the other wire to the frame. How does this regulate the voltage for anything connected to the yellow wire? Bear with me here on my comparison, but in my mind I see this like having a pipe with water flowing through it, then T'ing off that pipe and putting a valve on the off-shoot, trying to regulate pressure through the main stretch of pipe - it doesn't make sense!
Hopefully this makes some degree of sense and someone can clarify this for me.
Old 01-05-2016, 02:21 AM
bergerhag's Avatar
It is a zener diode voltage regulator. It cuts off the tops of the positive ac phase and almost all of the negative. Basically it shorts excess voltage to ground. The input resistance would be the coil itself in bike applicaton.
Old 01-05-2016, 03:00 AM
So as long as it ties into the yellow stator wire and grounds to the frame at any point it will in theory function as designed?
Old 01-05-2016, 08:03 AM
pscook's Avatar
pscook pscook is offline
Yes. Don't think of it as a water valve regulating the "pressure" of the main pipe, it's a relief valve managing the "spikes" in pressure along the main pipe. Like having an expansion pipe to manage the water-hammer in house pipes, or an expansion tank in a closed-loop water system.
It made sense to me when someone used the term "clipping" of the excess voltage.
Phil
(New bike pending...)
Old 01-05-2016, 01:42 PM
jostby jostby is offline
If I remember right you have a '01 or close to it? Yes, the voltage regulator is tucked under/inside the frame behind the steering stem back then.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 01-05-2016, 01:49 PM
Thanks go to the both of you. The bike should be lit up in no time.
Old 05-08-2016, 11:39 AM
ec gasser ec gasser is offline
Hi great post and very helpful. my question is does it mean my regulator is knackered if my lights are dim when my bike is ticking over but go very bright and blow when the bike is revved. they used to be ok but I have just fitted a new stator and I am now having problems. I have two wires from the regulator a yellow (going to the stator) and a black (going to ground) Any advice as to sort this would be great thanks.
Old 05-09-2016, 10:42 AM
it's odd that your problem would start after replacing the stator, I would double check that the ground/earth wire from the regulator (and power wire connection) have good contact using emery cloth or sandpaper at the connections. If all is good then yes, a bad regulator will do exactly as you describe. Please post back what you find for a correction to your problem.
'00 XC250 (mine)
Old 05-11-2016, 03:23 PM
so after checking the wiring on the reg and all connectors were clean and made good contact I was getting a voltage reading of over 20 volts when the throttle was opened. I have now replaced the regulator and all is well with voltage readings where they should be at just over 12v
Voltage Regulator rootsnrocks Enduro Electrical & Wiring 2 07-02-2012 07:02 PM
voltage regulator for 05 ec300 ktm300exc Enduro Electrical & Wiring 2 05-22-2010 03:26 PM
Voltage regulator sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-22-2008 08:36 PM
