Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > "Wanted to Buy" & "Want To Trade"
"Wanted to Buy" & "Want To Trade" Bikes or Parts
Old 11-22-2017, 05:36 PM
Originally Posted by PEB View Post
The 07 setup I have has what looks like 11 to me on it.
Stamped around the back, beside where the line connects?
Old 11-22-2017, 07:00 PM
PEB PEB is offline
Yes right where you described
Old 11-23-2017, 02:19 AM
(F5)'s Avatar
(F5) (F5) is offline
Typically 11,12 or 1\2"(12.45)mm. Its all about leverage. Smaller bore means more leverage but more travel. Radial are larger bore but lever acts on it differently. .
There is a sweet spot for caliper to mc ratio.
Try this, there is a sweet spot for lever position. Your hand works best at some point. I've only just realised I had it out too far. But then again I'd rebuilt the mc and it had less travel to it. So what was best compromise before was clumsy later.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-23-2017, 04:20 PM
chopper chopper is offline
I think that the main performance difference between your GG and the CR250 is the rotor diameter, GG is 260mm whereas the Honda is 240mm. I would first try an oversized rotor ,I think then that you'll find it similar. Next try a braided brake line, at that point you'll have the same mc, line, caliper, and rotor on both bikes. If you are still not satisfied then you can swap to the 07-present CRF 250/450R only (not 250/450X or 07 cr125/250) front mc which has an improved feel at the lever compared to the earlier unit. From what I can tell the GG mc is the same as the pre 2007 Honda models so if you were to make all of the suggested changes you could obtain greater performance from the Honda vs the GG.
Old 11-24-2017, 12:14 AM
(F5)'s Avatar
Yup. Again leverage. Bigger rotor means longer arm you can pull up the hub with.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 11-24-2017, 12:51 PM
Moto7man Moto7man is offline
I already installed a 260mm Wave Rotor and a braided line.Its good now, strong and progressive but it won't lock up the front wheel under a load like my GG.
―Comedian Lewis Black
-Unknown Sardaukar
Old 11-24-2017, 02:03 PM
(F5)'s Avatar
Try a stick in the spokes
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 11-25-2017, 11:15 AM
Thanks for all posts! I have been xmas shopping and doing the holiday thing so I haven't had time to read them all. I'll try to look them over and post an update in a few days,
-Unknown Sardaukar
Old 11-26-2017, 11:11 AM
My bad, I think you are right. I installed a Braking Wave Rotor HO09FID. I checked the rotor this morning it is 240mm not 260mm, so that was my bad.
-Unknown Sardaukar
Old 03-11-2018, 05:34 PM
I just installed a Nissin front master cylinder from a 2011 GG on my Honda. BIG DIFFERENCE. Just a lot more feel and power. I will give her a test ride and post an update.
-Unknown Sardaukar
Crossover Parts ID # 4 Front & Rear 2003 EC 300 Brake Master Cylinder Rebuild Kit(s) tprnottp Enduro Chassis & Body 1 03-27-2017 05:50 PM
Nissin Back Brake Master cylinder seal kit smithopolis Enduro Chassis & Body 5 08-17-2015 09:45 AM
WTB-Front Brake Master Cylinder Sight Glass Needed GasGasDreamer "Wanted to Buy" & "Want To Trade" 3 03-03-2015 11:11 AM
Front brake master cylinder gassergrant Enduro Chassis & Body 2 09-15-2013 03:31 PM
Master Cylinder Front Brake Rebuild - Other Brand kits? jdalton1 Enduro Engine - 2 stroke 5 03-23-2013 03:07 PM
