Old 01-15-2018, 04:36 PM
ljdb ljdb is offline
Default 2015 ec250 pv nut/cover loose
hi guys i went to remove the 27mm nut that covers the power valve adjust and it just spins. The treaded part in the engine case moves with the nut. Does anyone know if it has a securing nut on the inside or it should be a press fit and not move? cheers
Old 01-15-2018, 08:56 PM
gasgasman's Avatar
The male threaded insert is press fitted and held in with Loctite.
From the cut away view, looks like it just slides out.
2015 ec250 interchangeable radiator braces/guards ljdb Enduro Engine - 2 stroke 2 07-02-2017 12:46 AM
New to gasgas. Just purchased 2015 ec250 ljdb General Discussions & Announcements 16 06-30-2017 06:56 AM
Any ideas on 2015 EC250 jetting? MOGaser Enduro Intake/Carburetion - 2 stroke 2 12-20-2014 06:40 PM
ec250 stator unit 5 of the 8 coils are burnt and loose KTMAndy Enduro Electrical & Wiring 0 10-19-2013 03:18 PM
