Old 02-04-2011, 10:30 PM
orangezuk orangezuk is offline
Default 2011 125 6 days jetting
I just picked up a 2011 125 6 days and I need to see if there is anyone out there with experience jetting these things.
I'm in central AL 400 ft ASL and temps will go from 30*F to 65*F in a weekend. I understand that the little bore bikes are more sensitive to changes...I'm just looking for some general tips...
Stock:
160 MJ
35 PJ
N8RF 3rd
1.5 out AS #7 Slide
It seemed way lean so I went to this and I still haven't cranked it...
172MJ
42PJ
stock needle & pos
will adjust AS for temp
#7 slide
thanks
Ryan
Old 02-05-2011, 12:25 AM
twowheels's Avatar
No jetting tips, but how about posting some pictures of that bad boy? Clay said he had a couple 125 Six Days left and I told him to check the crate and make sure they didn't just ship over a couple hundred pounds of rocks - I've never seen one, and I would hazard a guess that most others haven't either.
Oh, and if you get a chance to run it across the scale, tell us how much water it displaces
Thanks
Steven Beane #275
afterhourscycle.com
Old 02-05-2011, 04:39 AM
fury1's Avatar
fury1 fury1 is offline
Saw one at our banquet a couple weeks ago,gabriel cycles out of worcester,ma. Had it at their display,looked very trick!!!
Old 02-05-2011, 03:52 PM
As soon as I get it put back together I will post some pics.
I did some research and found that KTM 125s (the only 125 I could find with a keihin 36mm carb) started with a 198 MJ and a 42 pilot so I am thinking I am still way too lean. The biggest mj I have is a 190 so I may not get to ride it this weekend but at least I have a starting point...
Old 02-05-2011, 06:50 PM
MattR's Avatar
MattR MattR is offline
You may find some 36mm PWK jetting specs in this thread. The Husky 125 riders have run both 38mm and 36mm.
http://www.cafehusky.com/threads/2-s...e-thread.8881/
Matt
Current: 2009 Yamaha FZ1
Old 02-05-2011, 09:04 PM
Only additions are an o-ring chain and the barkbusters...I've got a handful of jets and needles to test tomorrow....
Old 02-05-2011, 10:15 PM
smoke229 smoke229 is offline
Oh boy my son would make that thing scream for its mommy and like it.
Old 02-05-2011, 10:49 PM
twowheels's Avatar
Originally Posted by orangezuk View Post
Yummy ... !
Steven Beane #275
afterhourscycle.com
Old 03-29-2011, 04:56 PM
jayc jayc is offline
I'm running a 168 MJ in my '02 125xc, if that helps. I am also running a 42 PJ and a #7 slide. The PJ is fine, but the #7 slide is way too rich. I plan on grinding it into a #5 whenever I get around tuit.
JayC
Old 04-02-2011, 12:38 AM
MJC MJC is offline
JayC
It doesn't work that way. A #5 slide is richer, meaning it has a 2mm smaller cutout than a #7 slide. A #7 slide will be leaner at the transition off the pilot jet and into the needle. I've done this mod a bunch of times to various bikes, and have always been happy with the results.
2011 300 six days shock jtgas General Discussions & Announcements 30 01-10-2012 06:21 AM
jetting for ec250 2011 six days taku60 Enduro Intake/Carburetion - 2 stroke 2 02-01-2011 11:01 PM
2011 250 Six Days danielm General Discussions & Announcements 31 11-24-2010 02:13 PM
