Old 12-27-2018, 02:31 AM
Undertow Undertow is offline
Well, now we have mixed signals from GG. One technician says it works, one says it doen?t.
The easiest way to check is loop pins 4 and 13 in the connector and see what happens
The wiring plan is the same in the connector between 18 and 19, so no harm should come, even if the ECU program doesn?t support this, right
Old 12-27-2018, 06:55 AM
gasgasman's Avatar
You risk shorting out the module.
Old 12-27-2018, 08:36 AM
GASGASCWB GASGASCWB is offline
Thumbs up
Originally Posted by gasgasman View Post
No.
According to the GG tech, if the '18 CDI supported the MAP switch, they would have added it.
You can buy a '19 CDI and add the switch.
Exactly what I think!
IF it worked, it would not be only the selector switch that would make a difference...
Old 12-27-2018, 08:44 AM
In my humble opinion, I do not think such changes are worth taking the risk!
The 2018 models already have many electrical problems but have gradually been solved...
These "adaptations" are a potential problem!
If it was just buy the selector switch and plug it in according to the diagram, ok!
But if the CDI's are different (see my post above with the 2018/2019 PN's), you will not be putting the key or just changing the position of the pins that we would get the SUN and RAIN maps with some safety for the motorcycle's electronic / electric system!
Converting 2018 EC/GP to XC start switch Keg Enduro Electrical & Wiring 6 02-28-2021 04:25 PM
Swingarm Decals GG300 2018/2019 Doc Brown Enduro Chassis & Body 9 10-14-2019 10:18 AM
Aftermarket Plastics for 2018/2019 EC Models RudolfHucker Enduro Chassis & Body 0 11-08-2018 07:12 AM
Adding a map switch to 2018 XC/EC AZRickD Enduro Electrical & Wiring 9 08-29-2018 12:25 PM
Start/Light switch and kill switch Doc Brown Enduro Electrical & Wiring 0 07-27-2018 12:43 PM
