Old 12-05-2018, 10:54 PM
Homer Homer is offline
Default FSE400 compression test
Hi all, anybody know the compression test figures for the FSE400? Mine won't start and I'm suspecting low compression may be the problem.
Old 12-06-2018, 04:41 AM
RBrider's Avatar
RBrider RBrider is offline
My former DRZ 400S should have read about 145 lb, but when it got down to about 40 lb , it quit running. A fresh piston kit made it run like new again.
Your FSE will probably be in the same ball park for compression numbers.
RB
Old 12-09-2018, 03:26 PM
Harry's Avatar
Harry Harry is offline
Hi Homer,
Please see the attached page form the GG workshop manual.
File Type: pdf Compression Check fse400-450_motormanual_02-03.pdf (54.9 KB, 22 views)
Old 12-12-2018, 05:59 AM
expirmininkas expirmininkas is offline
Thank you,
But the engine is equipped with decompressor. So, is value (10 kpa), indicated in manual, with the decompressor working? What I want to say, that before engine is started, decompressor lowers the compression for easier starting. So, is 10 kpa with decompressor lowered compression? Or FSE 400 does not have decompressor at all?
Old 01-18-2019, 06:46 AM
Hello fellows, any suggestions?
Compression test Upyourkiltbatman Enduro Engine - 2 stroke 13 08-20-2023 10:38 PM
Re commissioning the fse400 nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 2 10-27-2018 09:18 PM
ec250 2003 compression test readings gasgasquebec General Discussions & Announcements 1 08-05-2009 11:23 AM
FSE400 throttle tube nitroman Enduro Chassis & Body 0 12-22-2007 05:17 AM
Fse400-02 plastic raggamuffin Enduro Chassis & Body 1 01-30-2007 02:34 PM
