Old 02-09-2023, 09:09 PM
brider brider is offline
Default '03 EC300 Nissin front master cyl kit?
I can't seem to find on-line a rebuild kit for the Nissin front brake master cyl on my '03 EC300. Gotta be a common kit for many years, what's a good source, for this and the rear brake and clutch, too?
Old 02-10-2023, 03:15 AM
Easy as, but, as usual you dont say which planet you live on.
At some point the masters get oval bore as ally bore. Some places will offer stainless sleeve insert. Or buy another low mileage one of same size and outlet.
Check carefully the size of master cylinder. Front will be 11mm, but rears change. Cast on the side.
Old 02-17-2023, 08:35 AM
Touche' ! Got me there, although in this day and age I was ASSUMING an on-line source, which doesn't care which planet I live on.
I'll continue to search, but I would imagine it's common to swap in a non-Nissan M/C & lever unit with the same bore & outlet config.
Old 02-17-2023, 02:58 PM
ditezz ditezz is offline
Replace the Nissan with a brembo .All you need is a brembo banjo bolt as it is a different pitch but still 10mm.Putting a MC with a smaller piston will give a softer more progressive pull .Personal choice though ,I found the Nissan way too abrupt
Old 02-17-2023, 05:43 PM
Ahh, you want an New Zealand site
https://lamoto.co.nz/daytona-nissin-...pair-kit-11mm/
Old 02-17-2023, 05:51 PM
Rear brake is a little trickier, there a a couple of sizes. It will be cast into the cylinder, something like 1/2 which is a fraction of some antiquated measuring system involving inchworms or something ?
The clutch back then I'm not sure if it used DOT4 brake fluid or mineral oil. Will be written on the clutch cylinder cover.
You will need the right seals to match. DOT will be something like Nitrile and oil; EPDM, but you dont need to know that, just what type of fluid they use for the kit.
WTB-Front Brake Nissin Master Cylinder 2010 or later. Moto7man "Wanted to Buy" & "Want To Trade" 25 03-13-2018 10:49 PM
Nissin master pump banjo bolt measures Fesart Enduro Chassis & Body 1 03-08-2015 12:30 PM
2002 EC300 front brake caliper (Nissin) Diedrix "Wanted to Buy" & "Want To Trade" 8 07-29-2014 12:48 PM
Nissin Master adddy Enduro Chassis & Body 2 07-17-2014 11:03 PM
'06 EC300 Nissin Front caliper brider Enduro Chassis & Body 7 12-01-2012 02:09 AM
