Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > "Wanted to Buy" & "Want To Trade"
"Wanted to Buy" & "Want To Trade" Bikes or Parts
Old 01-29-2018, 12:28 PM
Stu1 Stu1 is offline
Default Wanted 450 fse starter clutch see picture
Attachment 7332Hi if anyone has starter clutch they would like to sell , or if anyone could tell me if it is left hand or right hand thread , and what is in the middle of the two parts that would be a help.
This is for a 2004 450 fse .
I am located in the U.K.
Old 01-30-2018, 12:07 AM
Gasser Nate's Avatar
That piece isn?t exactly called the starter clutch, they call them a back torque limiter. There was a torque spec on it but I can?t remember anymore. Designed to slip a little when the motor kicks backwards occasionally. The starter clutch is on the back of the flywheel. As where to get one from , sorry no idea mate.
Old 01-30-2018, 02:04 PM
Thanks for that , at least I now know what it is called .
I don?t suppose you know it it?s a left or right hand thread.
Old 01-30-2018, 02:08 PM
I am pretty sure it is a rh thread, as I don?t have a torque wrench that does lh threads.. but it was 04-05 when I was last playing on them!
Old 01-30-2018, 02:44 PM
Cheers , have you had one apart , I would like to know what is in the middle, so perhaps I could repair or make whatever it is that give it resistance or torque , mine is just spinning, someone has tried welding it in the past , but obviously that defetes the object of what it does.
I have replaced the sprag clutch , if I can fix this I can get the bike running.
Old 01-31-2018, 05:17 AM
From the top of my head they had what looked like big dished spring washers, the nut could be tightened to give more or less slip, they were updated a fair few times from the factory till they changed design in '06 IIRC. The starting systems were never great on the gasser 4t's, when coupled with the early magnetti marelli ignition systems they were lucky to start. Even new. They got a lot better with the '09's that had the japanese kokusan ignition systems.
Old 01-31-2018, 01:06 PM
Many thanks for that information , at least I may be able to bodge it up somehow, providing I can undo the bolt .
That?s if I don?t have any luck sourcing a replacement .
WANTED. 450 fse 2004 starter motor Lambretta man "Wanted to Buy" & "Want To Trade" 0 12-09-2017 05:36 PM
wanted.... starter motor for gas gas quad richy5118 "Wanted to Buy" & "Want To Trade" 0 12-21-2015 06:40 AM
Starter clutch / gear problem iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 12 01-28-2011 02:45 PM
2002 ec400fse starter clutch jason r Enduro Engine 4 stroke (including EFI & Exhaust) 6 09-09-2009 04:47 PM
