2013 250ec wont rev out
As title 250ec wont rev out after about half throttle just splutters, short shift it absolutely fine, standard jetting, bike is in uk ,Any info on jetting what everybody else is using. many thanks.
Sounds rich on the main jet
What are your jetting specs? |
jetting spec
n1ef needle 172 main jet
Check everything is ok with your carb.
Don't overlook the possibility of a dud spark plug either, you would be surprised how many "carb issues" have boiled down to an ignition fault. |
+1.. The stock Denso plug wasn't the greatest for me..
Also the stock jetting while grunty off the bottom was always too rich and would smoke and load up heavily. It always took a fair bit to clean it out before the bike would come on song properly. |
Ditch that poxy needle.Look at the sticky threads on jetting.
250 ec wont rev out
Just checked power valve all seems to be working ok, started first flick of starter, back thinking it may be carb, any more ideas, settings, will strip carb later, any info.
Has it happened since brand new?
Pull the head off and see if the piston is in backwards. |
gasgas wont rev out
Scotty no has not done it from new just recent, just took carb off and cleaned could not see any problems with it, So far checked power valve cleaned carb,new air filter, new plug checked all electrical connections will test ride tomorrow night to see if any different,anybody any other ideas.
See how your test ride goes. Is it billowing smoke while doing this? Has there been a significant change in the weather? Any chance of the fuel going stale or being contaminated?
Another wont start question | Quicky1980 | Enduro Engine 4 stroke (including EFI & Exhaust) | 22 | 08-12-2013 06:18 PM |
Gas Gas 250 wont tick over | Wilksiee | Enduro Engine - 2 stroke | 11 | 03-24-2012 05:20 AM |
Front end wont turn | Malcolm | Enduro Suspension | 4 | 05-23-2011 01:56 PM |
02 EC 300 wont start | GENO 300 | Enduro Engine - 2 stroke | 0 | 09-21-2009 10:02 PM |
wont start | clerky clerk | Enduro Engine - 2 stroke | 8 | 11-01-2008 01:18 PM |
