Old 04-22-2010, 12:58 AM
Gi_GASGAS Gi_GASGAS is offline
Default 400 FSE Fuel Pressure
Anyone know what the fuel pressure is in the supply line on and EFI bike?
cheers.
Old 04-22-2010, 08:35 AM
bergerhag's Avatar
A rep from the swedish importer told me system pressure is 3 bar.
Old 04-22-2010, 02:47 PM
cool man, cheers
works out to be 43.5psi so a standard efi pressure reg will do
Old 04-22-2010, 03:20 PM
bergerhag's Avatar
Why would you need to put in a std regulator? Are you replacing your fuel pump?
Old 04-22-2010, 05:10 PM
the engine is being used in a kart
the pump is shagged so it wont use the original tank assembly.
cheers
Old 04-23-2010, 01:40 AM
bergerhag's Avatar
pics and videos please!
Old 04-24-2010, 02:06 AM
ill get onto it but it is a work in progress so patience will be needed, myabe ill put a topic in the 'other' section as there isnt really a section for what im doing.....
EC 300 cylinder pressure pevs Enduro Engine - 2 stroke 33 05-30-2023 01:58 PM
No oil pressure when doing wheelies Emil123 Enduro Engine 4 stroke (including EFI & Exhaust) 14 12-26-2014 09:10 PM
Minimum tyre pressure stay_upright Enduro Chassis & Body 13 07-22-2009 10:47 AM
How much fluid and pressure and sag? gasser Enduro Suspension 0 04-16-2009 02:16 PM
Higher pressure radiator caps Skidad Enduro Engine - 2 stroke 5 11-03-2008 03:26 PM
