Old 02-17-2019, 12:23 PM
mattyboy mattyboy is offline
Default gas gas ec200 2003
Ok think i'm getting somewhere or maybe not i don't have any power up front but have these unconnected of the stator . Not sure what this is tucked up in the frame a vr? has a yellow wire coming of it connected into the loom.I'm lost as to how i get the power up there WP_20190217_13_42_05_Pro.jpg
Old 02-18-2019, 10:16 AM
slocalspode's Avatar
slocalspode slocalspode is offline
Yes, that is a voltage regulator. It is in the system to knock
off the high voltage peaks in the AC current wave.
If I remember it is attached to one of the yellow wires in the
harness, and grounded to the frame with the black wire.
There is no power wire exiting from the regulator. It is more
of a ballast/buffer in the system.
It has been years since I have worked on any of my GG electrical
systems, so I an hesitant to make and suggestions.
My feeble guess is the white wire runs the CDI loop and the Yellow
runs the headlight / running light / horn, etc..etc... Depending on
if your bike is an XC or an EC it will power the brake and turn lights.
Sorry I can not be more specific.
JJ
Old 02-18-2019, 04:17 PM
Neil E. Neil E. is offline
White wire is stator full AC output intended to be rectified/regulated for DC battery charging. Would not be connected to anything on your bike.
Yellow wire is stator reduced AC output intended to be regulated for lighting.
The bottom of the windings is chassis/frame ground. Thus you need to work with the yellow and ground to get your lights operating. Follow the yellow wire everywhere and it should wind up at the headlight switch. Comes out of the switch and goes to the LO headlight bulb. Other side of the bulb goes to ground. Engine has to be running for the lights to work.
2011 EC250E
GG Headlight honuki250 "Wanted to Buy" & "Want To Trade" 8 07-22-2016 01:01 PM
I need some headlight help iamovru Enduro Electrical & Wiring 2 08-15-2014 07:35 PM
IMS DHH headlight jdosher Enduro Electrical & Wiring 0 03-04-2011 01:18 AM
Headlight Help loopole Enduro Electrical & Wiring 3 05-28-2008 02:08 PM
