Old 12-13-2008, 09:52 PM
thumpercb's Avatar
thumpercb thumpercb is offline
Default 200 06 stock jetting???
looked at the chart on here and no 200....i have two friends who just have bought used 200,s ...and are intrested in a starting point.,. needle size and jets installed on factory 200 with boyseen valve ..fmf pipe combo..???
"The empty can rattles the most"(James Hetfield).
Old 12-16-2008, 07:05 PM
thumpercb's Avatar
Default please someone reply
the manuals are no help on the 200...does anyone around 1000 to 1500 ft know there stk 200 jetting and needle..
Old 12-16-2008, 07:54 PM
2 strokes 4 life's Avatar
2 strokes 4 life 2 strokes 4 life is offline
I would say a 45 pilot, 185Main and needle in mid position should be a good starting point. Look in the 2 stroke jetting section.
2002 Gasgas EC250 (gone not forgotten)
2012 Ktm 300xc
2001 Gasgas EC300
Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!!
Old 12-16-2008, 07:57 PM
This is all we got in the STICKY for a 200
Bike year & model = 2003 EC200
Temperature (degF) = 68 - 100
Elevation (feet) = 1300 – 2500 ( roughly varying )
Main jet = 178
Pilot jet = 48
Needle & notch = N3HJ - 2
Air screw setting = 2 3/4
Throttle valve/slide = 5
2012 Ktm 300xc
2001 Gasgas EC300
Old 12-16-2008, 08:04 PM
Rick's Avatar
Rick Rick is offline
You just might try looking in the 2stroke jetting / carb thread.....
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 12-16-2008, 11:06 PM
That was the only 200 from the thread sticky.
2012 Ktm 300xc
2001 Gasgas EC300
Old 12-17-2008, 06:37 PM
thumpercb's Avatar
Default thanks
yea i looked but found no 200 info but thank you for posting what youve found....ill keep looking at this thread just in case someone just hapens to reply with stock jets and needle number,,
Old 12-17-2008, 06:55 PM
Rick's Avatar
Let me look when I get home, I have my stock jetting spec'd from my 99 EC200, not sure if GG changed jetting spec's over the years or not.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 12-18-2008, 12:22 PM
bondo bondo is offline
Did you mention what year the 200's are?
We've got an '05 DE 200 with the variable ignition map, running an FMF
Gold Series pipe w/ Power Core II silencer / SA. We use NGK BR8EV plugs
We ride mostly tight woods at an elevation of approx. 500 -1500 ft above sea level.
After MUCH trial and error we settled on a # 40 pilot, LTR needle / clip
in the 3rd(?) position from the bottom and a 175 main (a 172 main will also work quite well).
The bike runs clean and crisp down low and doesn't starve for fuel on top.
Note: we usually run our ignition on the "Rain" setting.
Last edited by bondo; 12-18-2008 at 12:30 PM. Reason: spelling correction and additional info
Old 12-18-2008, 01:30 PM
iancp5's Avatar
iancp5 iancp5 is offline
Just stuck my jetting up on the intake / carb section
where to go from here. jetting q. dank Enduro Intake/Carburetion - 2 stroke 105 04-11-2011 04:25 PM
05 ec 300 stock jetting randy Enduro Intake/Carburetion - 2 stroke 15 09-08-2010 06:53 PM
04 ec 300 Jetting lordfeyr Enduro Intake/Carburetion - 2 stroke 12 01-26-2010 03:16 AM
jetting macho comacho Enduro Intake/Carburetion - 2 stroke 21 03-10-2009 03:11 AM
02 ec 250 jetting help crem55 Enduro Intake/Carburetion - 2 stroke 9 07-12-2007 01:44 PM
