Old 09-01-2011, 05:39 AM
Default Revised Jetting Specs NEDW
Here he goes again.. they all say
Today was a miserable day in the far north (aus). 25C 65% humidity and a bit cloudy. Pretty normal! Elevation 300M+
Previously I have ran the following setups
42P N3EW#2 178 - Bit rich off bottom. Strong mid to top.
38P N3CH#2 178 - So clean off the bottom but a tad lean in the mid range. Ran clean but lacked balls.
38P N3EG#1 175 - Rich idle, then lean and crisp throughout. Was in the middle of summer at elevations approx 900m.
38P N1EF#1 175 - Too rich all over. It ran but it loaded up in the tight and smoked everywhere.
Now today, today.. I decided to try a Suzuki RM250 needle. The ones the KTM guys (*nudge*) have been ranting about. Started with 42P NEDW#3 172 (triple taper with a rich top end). Bike ran but required to come out a good few turns on the AS to get a consistant idle. Also some burbling when on the needle howver very punchy and powerful. Very on off though with the burble. This was meant to be a smooth linear setup from what I had read.
Dropped the pilot to a 40 and lifted the clip to #2. Yep! That hit the spot. AS set at 1.5 it starts and idles well. No hanging, no bogging. Crisp snappy response right off idle that just keeps on building all the way through. No really hard transitions onto the pipe like the N3 range. A little bit of the typical burbling when at part throttle without load but nothing compared to how it was at clip 3. Plugs looks good and bike feels great. Its very responsive to throttle like the N3CH#2 was, but doesn't have a lean whole in the middle.
The difference being Suzi runs lean-rich (bottom-top) where the N3 run the other way. These needles just work and I'd recommend anyone else who wants good performance to give em a try. By far the best setup I've ran yet, and those who know me, know I've tried just about every combo under the sun.
Cheers, Jake
Old 09-01-2011, 08:54 AM
MJC MJC is offline
X2, absolutely the best setup I've used in my 11' 250 as well. On my 250 I use the #3 position and 2 turns out on the AS.
Old 09-01-2011, 06:57 PM
jeffs2200 jeffs2200 is offline
I have an NEDJ I can try. How does that compare to the NEDW.
Right now I am running the N3CH #2. 38 pilot 175 main and a.s. about 2.
I really like the n3ch but I have not been able to get a consistent idle using it.
What would you suggest with the nedj? 40p, 2nd clip,172 main.
This is on my 11 300 with 38mm carb.
Old 09-01-2011, 10:53 PM
twowheels's Avatar
Cheers, Jake
Jake: Sorry to hear about the weather. If it was that nasty here I'd call in sick to work
What bike are you running - a 250 or 300? Vintage? Any other mods?
Steven Beane #275
afterhourscycle.com
Old 09-02-2011, 12:48 AM
Sorry its a 2010 Euro model 300 which uses the 38mm ASII (small bowl and flat metal cap) slide 7 non notched. S3 Head with black insert. Exhaust port flush with top of piston. Still large squish at 1.8mm.
The difference in the NEDJ is 2 steps leaner on the straight diameter than the N3CH and 1 step leaner then the NEDW/N3EW. I'd start by using it with a 42 pilot to compensate. I too found moving from the N3CH to N3EW cleaned up the idle issues.
So if you're using N3CH#2 I'd suggest trying the 42 NEDJ#2 172 and see how it feels. You can also get half clip adjustments (NECJ) etc.
Old 09-02-2011, 01:48 AM
not quite on topic, but if you riding v technical stuff (extreme enduro type) where you want a lot of traction and good bottom end would it be better to run a setup that is a bit richer at the bottom or would you rather have it crisp of idle?
Old 09-02-2011, 06:59 AM
On topic Matt
I agree sometimes a bit richer is nice as its more forgiving. I also find burbly rich more snatchy if that makes sense Ie. Burble then hit. The NEDW seems to be very linear and smooth in that you can control the power even at slight throttle openings and as you open more the power just builds. There is no burble down low or slow revving followed by abrupt power.
I rode some really tight 1st/2nd gear single track as part of my test run and while its crisp its not uncontrollable at all. Very very predictable but still makes gobs of power.
Old 09-04-2011, 03:48 AM
gg3's Avatar
gg3 gg3 is offline
Jakobi,what are you going to do now you've found the perfect jetting?Could you maybe work out world peace & fusion power? Good work,thanks for your efforts.
Old 10-15-2013, 01:06 PM
nambo-trev's Avatar
nambo-trev nambo-trev is offline
Originally Posted by nickp View Post
As1 carb, idle screw not turned in very far just enough to lift slide slightly, do you know what causes hanging idle I have never had this on any other bike. many thanks.
A lean condition causes your idle to hang
trevor
Old 10-15-2013, 01:18 PM
nickp nickp is offline
What is the best remedy for this condition bigger pj, at moment 40pj,175mj,nedf 2nd clip as 1.5 turns.
2010 EC300 Factory Jetting Specs - WTF? JP4 Enduro Intake/Carburetion - 2 stroke 197 07-04-2011 11:03 AM
torque specs kstreet Enduro Engine - 2 stroke 1 01-28-2011 07:05 PM
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
Torque Specs steve Enduro Engine - 2 stroke 8 02-26-2008 09:30 PM
