Old 12-13-2019, 12:58 PM
(F5)'s Avatar
(F5) (F5) is online now
I was getting some bad vibration so I did this. There was more movement than I expected. I'd just done the crank a couple of rides before. The left crank bearing will have some slop.
. . . and the lower engine bolts had undone. Buggers to get to with water pipe in way. Oh look. Vibration sorted. Mental note to recheck them. And loctite.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 12-29-2019, 10:25 AM
derbimarcel derbimarcel is offline
Originally Posted by Nicktamps View Post
this is the only one i havent checked. bikes currently on its side awaiting a new clutch cover from enduropuro (has anyone had any dealings with them? i cant seem to get a reply by email or facebook. starting to get a bit concerned) once its done ill get the tank off and check. also ive bought new rubber silent blocks for the radiators as its missing some. the radiator is directly bolted to the frame. think that might be causing a bit of vibration
I order many things by Enduropuro good company.
Maybe worn exhaust o-rings?
Old 01-26-2020, 01:15 PM
Nicktamps Nicktamps is offline
Thought I'd post in here what it was in the end. So basically bought the bike second hand. And someone has had the swingarm off in the past. Basically the nut on the main pivot on the swingarm was bottomed out on the thread of the bolt. Put a washer behind it that I borrowed from work and she's all good
Old 01-27-2020, 07:07 PM
Zman's Avatar
Zman Zman is offline
Congrats on the inexpensive fix! Good thing you give yourself a price break on labor ;-)
Old 01-27-2020, 07:08 PM
Zman's Avatar
Congrats on the inexpensive fix! Good thing you give yourself a price break on diagnostics and labor time ;-)
Old 01-28-2020, 01:37 PM
Glad you solved it! Good point to pass on to others that have problems
08 ec 300 vibration fatdaddy Enduro Engine - 2 stroke 2 02-24-2012 10:58 AM
vibration fix. stainlesscycle Enduro Engine - 2 stroke 2 02-22-2012 07:49 AM
vibration peanutsracing1 Enduro Chassis & Body 3 04-19-2011 08:55 PM
Vibration mikeh Enduro Engine - 2 stroke 2 04-21-2010 04:18 PM
foot peg vibration MIKEWA Enduro Chassis & Body 3 03-19-2007 08:42 PM
