Old 02-17-2019, 05:03 AM
Started it and did 3 laps of the back yard!
Old 02-17-2019, 11:38 AM
Elvis74 Elvis74 is offline
Thanks
I use a KYB SSS fork from a 2007 or 2008 YZ250, with original GasGas wheel and the onlins 888 shock
Gesendet von iPhone mit Tapatalk
4 strokes are only good for power generators
Old 02-18-2019, 11:01 AM
masterbill masterbill is offline
Covered the plastic on my 300 which is being rebuilt.
It's a bit like me - looks better from a distance.
Old 02-26-2019, 05:43 AM
Anders's Avatar
Anders Anders is offline
On Saturday, my friend Magne and myself did our first race of the year. Both on Gasgas, his 2019 250 an my own 2015 200. Here in Norway, it seems like Gasgas sales are good, there are some new Gasgas owners and bikes at every meeting now.
A trio of 18 and 19 models
I was completely exhausted after two hours in the wet snow.
En route to exhaustion
Magne in somewhat better shape than me.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 02-27-2019, 02:41 AM
RBrider's Avatar
RBrider RBrider is offline
You Norweigans are a hearty bunch (Sorry for the incorrect spelling) Good to hear that GG is doing well there.
RB
Old 03-11-2019, 06:13 AM
hadfield4wd hadfield4wd is offline
Getting a top end and adding some bling.
Sent from my SM-G960U using Tapatalk
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
2001 Triumph Speed Triple for my 20 year old
2000 GG XC250 for my 20 year old
2003 Honda Rancher 350 for the wife
Old 03-11-2019, 07:56 AM
dzhitshard dzhitshard is offline
In the past 8 weeks Penelope, my 2018 XC300, has received:
XC360 bar mounts. Extremely pleased with this purchase, again. The GG fit isn't what I want but the performance of the part make up for it's limitation.
Billet water pump impeller
After seeing the OEM one and how it's built compared to an Austrian one I almost closed the cover and not installing this. The GG OEM part isn't going to overheat and fold like the Austrian one. I bought the part though so I installed it, no measurable difference compared to stock. I would not buy this again.
RK tech billet head.
What a huge difference straight out of the box. I wish I would have bought it right out of the gate so I wouldn't have spent so much time chasing jetting and engine noises.
Rekluse Core Manual # RMS7017001, newly released by Rekluse. Specific part number for the 2018/2019 bikes, not the one from the 2017 with an extra spacer gasket. Don't have enough time on it to warrant an opinion yet, however the Rekluse center hub has significantly more oil passages than the OEM center hub I removed. Hopefully it'll help & I won't lose more inner frictions. I can't for the life of me understand the passages on the OEM hub. At one point there's probably 1/3 of the circumference of the OEM hub that has ZERO oil passages drilled in it.
Bullet Proof Designs chain block guard & TM designs KTM "Factory" chain block.
I had the TM chain block in my parts box from a bike I got rid of before the OEM block needed replaced. I was installing the BPD chain block guard and the GG OEM chain block is pretty light duty imo so I figured I'd go ahead and install the TM why I had the thing apart. TM chain block is a KTM part number and the Fit was perfect.
BPD swing arm guard. This is also a KTM part number. The swingarm tab dimensions are the same as KTM so the tabs align properly. Unfortunately the GG and KTM swingarm are not shaped the same and I found that this guard doesn't fit the GG as well as it has on the last 2 Austrian bikes I've had it on. The bosses on the guard do not contact the swingarm without shimming and this puts all the lateral load on the threads for the cap screws you have to drill and tap into the swingarm. As delivered I feel the BPD part only offers marginal protection from an impact to the forward swingarm tab. With proper shimming of the boss to dissipate lateral loads across the surface of the swingarm it offers appropriate protection from impacts.
If I get another GG I'll install it again.
GP front axle lever. I don't even know why I bought this, but after installing it and changing the front wheel the last 3 times I'm glad I did. I've lived without one the last 5 years but I've also bought a new ktm axle and a couple axle nuts after damaging the axle nut threads removing them in haste. Having this lever should eliminate the threat of that happening again as I hastily fix a flat, change brake pads at an enduro restet etc.
Old 03-11-2019, 08:59 AM
Wimpy525 Wimpy525 is offline
[QUOTE=dzhitshard;189090]In the past 8 weeks Penelope, my 2018 XC300, has received:
I am working to get mine to work so the forks clear the lower mount, I have the X-trig clamp that comes on the GP, note the x-trig clamp you buy from X-trig is different from the one on the GP and the forks will clear the Mako mount.
I have done the same where did you end up with jetting? I have been chasing it forever even with the stock head, until I found an air leak, the wonderful engine assemblers in Spain managed to put the gasket in upside down backward. This blocks off about a 1/8 of the intake when wicked up it was drawing air in leaning out the mix. So new top end this weekend and tried some different jetting and had huge improvements.
Just wondering where you ended up.
Old 03-11-2019, 11:49 AM
Wimpy,
I had quit chasing needles already and slapped on a lectron that I had from an old project. Lectron sorted it out and set it to GG specs. I played with it and never got rid of the pipe bang and lean spots coming off throttle.
I swapped the head and the impeller as soon as the motor was cool enough to touch after a snow ride. I started it up in the same fuel, settings and conditions a few minutes later and it was noticeably more crisp without the strange noises (picture bad fuel noises but my fuel was good) and pipe bang was gone.
It's been cold and either 18" of snow or too sloppy here the last couple weeks so I haven't got to really put a load on it for long enough to get a good plug read. The times I have got her opened with adequate traction I liked what I felt and heard.
I'm not read up enough on the triples that you're talking about but I'll look into it. I'm considering pulling my mounts off and milling a 3mm deep, 5mm high relief into the bases so I can move my forks up in the clamps. Right now they are maxed at the first line on the tubes before the fork caps make contact with the Mako bar mount bases.
Old 03-11-2019, 03:30 PM
SS109's Avatar
SS109 SS109 is offline
Spooned on a new Sedona 907 on the rear to replace the Shinko 525. Also did DP rear pads, added a spring on the the pad retaining pin, and my own home made brake cooler that goes between the brake piston and pad.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
