Old 09-20-2019, 10:06 AM
siNN siNN is offline
Default Sachs rear shock Eye issues
Hi there,
Asking here as a last resort, I'm trying to fix the amount of play in my rear shock and have narrowed it down to the top mount.
Both the bolt and the spacers are worn and need replacing problem is I can't find the spacers anywhere. There's no part numbers, this is the internal rose joint:
http://www.splatshop.co.uk/shock-bea...as-ge12pw.html
If anyone could point me in the right direction that would be great.
This is the size of the original bushing:
Old 09-20-2019, 10:33 AM
You may be able to check with other manufacturers that use the SACHS shock.
i.e. BETA and Husqvarna.
Old 10-02-2019, 10:16 PM
Husqy's used the Sach's shock? Were these the Italian made Husqvarna's? Just curious...
Old 10-03-2019, 02:30 AM
Anders Anders is online now
Yes, the white KTMs use WP.
Old 10-03-2019, 03:11 PM
stumbled across this the other day. It may be what you are looking for
https://www.splatshop.co.uk/gasgas-p...cer-upper.html
Lower bearing replacement in Sachs rear shock Blambo Other GasGas Bikes/Quads 1 04-02-2018 12:51 PM
Service manual for Sachs rear shock MattR Enduro Suspension 9 10-19-2016 03:18 PM
07 sachs? rear shock packing/hard/no rebound? stainlesscycle Enduro Suspension 28 04-22-2013 06:58 AM
'10 Sachs rear shock setup Bailey28 Enduro Suspension 4 02-20-2011 02:44 PM
Sachs Rear Shock Manual MattR General Discussions & Announcements 1 05-05-2009 09:15 PM
