Old 08-07-2019, 11:23 PM
ECRider ECRider is offline
Default 2018 GP300 - Am I up for a New Conrod?
I'm doing an 80 hour piston change on my 2018 GP300 and found that that measuring with feeler gauges that the axial clearance of the big-end bearing is just out of work shop manual spec, measuring at 1.05mm (spec is 0.8 - 1.0mm max).
There is no up & down play in the conrod. The piston and barrel look OK apart from expected piston wear.
The manual states 120 hours for replacing the conrod.
Would I be pushing it to wait until my next piston change-out at say 150 hours to split the cases & change the conrod?
Thanks.
GG GP300 18
KTM 350EXC 17
GG EC 450, GG EC 250 08, KTM 525 EXC 06, KTM 400 EXC 01, XR400 97, VTR1000 98, VFR750 95, Husaberg FE400 96, RMX250 91, Maico 490 84, IT250J 81, RM250C2 79, Bultaco Alpina 250 77 - All sold
Old 08-08-2019, 12:09 AM
shawbagga's Avatar
shawbagga shawbagga is offline
Done 160 hours on my 250 with no issue. Don't plan on doing the rod until 300-400 hours at least. 120 hours may be under extreme use/racing.
'18 Gasgas XC250
Old 08-08-2019, 01:43 AM
Davehuge's Avatar
Davehuge Davehuge is offline
I'd be very surprised if you need a new conrod/big end at 80 hours or even at 150 hours.
Old 08-08-2019, 02:02 AM
Gasser Nate's Avatar
Nope. I would not even bother measuring it. I have seen so many cranks put together with such wildly different measurements on axial play. If no up and down play keep riding!
Old 08-08-2019, 03:40 AM
rodent's Avatar
rodent rodent is offline
I'm thankful that there was no interwebs in the 70's-80's, the 1000's of hours I put on my 2 smokers back then would have worked out a lot more expensive
Old 08-08-2019, 05:26 AM
Thanks guys, I'll put in new piston and ride
GG GP300 18
KTM 350EXC 17
Old 08-08-2019, 11:29 AM
Neil E. Neil E. is offline
If there is no up/down play don't worry about it. When the side play gets excessive, usually then it's time to check the up/down play.
2011 EC250E
Old 08-08-2019, 08:18 PM
(F5)'s Avatar
(F5) (F5) is offline
And beware that there is quite a lot of up down play in the mains. So dont get too scared of that.
My left main died and I replaced the rod at the same time. Starting to get some washer wear so might not have lasted another year or two. So 11 years is getting close to the limit unless you are riding quite a lot.
120hrs to replace? pfft!
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 08-09-2019, 01:25 PM
Moto7man Moto7man is offline
Default I don?t think so
My 2011 has the original crank. The GasGas cranks seem to be very tough. I would ride it and check it when you do the top end again.
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-09-2019, 10:57 PM
Yeah, I'll keep an eye on it at next top end and see if it's worn any more. I'm thinking it might have that much clearance when the factory assembles the crank
GG GP300 18
KTM 350EXC 17
2018 gp300 Colt New Bikes 1 02-10-2019 04:55 PM
First Ride 2018 GP300 Wimpy525 Ride Reports 7 09-24-2018 10:29 PM
2018 Gasser GP300 Colt GasGas Member Polls 27 07-12-2018 08:10 PM
2018 gp300 Colt Used Bikes 2 06-22-2018 08:14 PM
2018 GP300 instruments fred99999au Enduro Electrical & Wiring 6 05-08-2018 07:27 AM
