Old 09-21-2020, 07:53 PM
gasser's Avatar
gasser gasser is offline
Default 2018 ec300 Started manually first time
I've owned this bike for 9 months and it has always started perfectly hot or cold in gear or out with the electric starter until last Saturday. On the trail I fired it up with the button and the starter hung engaged and made a squealing noise. I shut the motor down but the starter kept going until it fried the starter relay. Battery seems ok and still has 13.5 volts. I have not taken the starter apart yet to see if there's any damage with it but will soon. I will start by checking my starter switch (a cheap chinese switch I got on Amazon) but if it's ok then I the only thing that makes sense to me is that the relay stuck. Am I missing something here? Could it have been a mechanical issue with the starter? The starter has never been wet modded but I assume the previous owner did the other recomended mods to get it working that well.
Old 09-22-2020, 12:51 AM
Yep sounds like a faulty starter relay. They can get welded contacts internally and short out. Double check the Chinese switch and look for any pinched wiring too.
2018 EC250 - Wins first time out! rossi Off Road Racer's Corner 16 03-23-2017 02:34 PM
Winter time rebuild on 06 EC300 knobbyboy Pictures & Videos 4 02-07-2013 07:53 AM
Going back in time on an EC300..... Keg General Discussions & Announcements 4 01-01-2011 03:18 AM
EC300 Revs when cold-started stevethebrit Enduro Intake/Carburetion - 2 stroke 6 07-10-2009 11:04 PM
0-60 time EC300..? stay_upright General Discussions & Announcements 15 03-04-2009 10:25 AM
