Old 02-11-2020, 02:43 AM
Anders's Avatar
Anders Anders is offline
When racing on Sunday, I noticed some clutch slipping, in places where it shouldn't slip. The clutch is a Rekluse Core EXP 3.0, so some slipping is to be expected
When I got home, I disassembled it to measure the discs. They measured OK, but then I noticed two hairline cracks in the Rekluse friction disk.
I have searced the 'net and spare parts seems to be readily available, so I asked my Norwegian Gasgas importer if he can get me the parts. I hope to have them in a week's time.
While I had it apart, I also installed the Rekluse brake pedal tip.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 02-16-2020, 02:06 PM
Anders's Avatar
The Rekluse ring was broken
I picked up the Rekluse parts from my dealer and mounted it all together, adjusted and tested.
And then I put on a new seat cover.
Anders
1986 Duc Mille S2
etc
Old 02-16-2020, 06:25 PM
(F5)'s Avatar
(F5) (F5) is offline
What I did on my GasGas.
Yesterday (my Sunday) trail ride:
1. Pulled a skilled and very stylish wheelie passing someone up a steep hill.
2. Immediately as it came down I had another bite of the cherry and with inverse relationship of skill and style, very nearly flipped that puppy, closest I've ever been and too dim witted to try reach the rear brake, got through on luck alone. Fortunately I didn't know the witness.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 02-16-2020, 07:55 PM
I've learnt that overtaking someone with style just motivates them to chase you, but out of control normally knocks the wind out of them ... good job!!
2003 txt250 Pro
2013 Ossa 280i
Old 02-17-2020, 12:27 AM
rodent's Avatar
rodent rodent is offline
Is the Rekluse pedal pad much bigger than factory brother? Part number?
Old 02-17-2020, 11:50 AM
Anders's Avatar
I will check and post it here, but it may take a day or two.
Anders
1986 Duc Mille S2
etc
Old 02-17-2020, 01:35 PM
gasgasman's Avatar
Yes it is.
https://motocentergasgas.com/shop?ke...ardware&page=2
Old 02-17-2020, 08:17 PM
If you buy the rekluse clutch cover (recommended..oem is thin) you get the brake pedal as well.
Old 02-18-2020, 12:59 AM
Anders's Avatar
The Rekluse tip is the same length (39mm) as the OEM. However, it is a bit wider at 36 vs 29mm. It is also quite a bit higher.
Here, I have placed the OEM tip on top of the Rekluse to see the difference in height and width.
The same setup, seen from above. Sorry for the out of focus image.
Part number
Anders
1986 Duc Mille S2
etc
Old 02-18-2020, 01:53 AM
rodent's Avatar
Part number
^^^^Thanks Gents
Thread Tools
Display Modes
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
