Old 06-08-2017, 08:20 AM
shawbagga's Avatar
New frame was 09(08 was older bigger frame). I'm not 100% on the rear pipe mount being the same as 10+. I'll send ya a photo of mine to confirm. Seem to remember different part numbers for fmf fatty of different years
Old 06-08-2017, 08:35 AM
arminhammer arminhammer is offline
Yes 09 is the new frame but the 09 and 10 up are different again. Small changes but most definitely different. I had a 10 up pipe on my 09.
Old 06-08-2017, 08:58 AM
shawbagga's Avatar
Yeah right didn't know they changed frame(do remember something about headstock additional gussets/reinforcement after some failures?). Yeah just looked at photos & rear mounts look the same so should be sweet
Old 06-08-2017, 09:07 AM
shawbagga's Avatar
Just looked on ebay they have different part #s?!
09=025115
10-12=025145
Something must be slightly different? Have a feeling it was to do with vertical shock can clearance
Old 06-08-2017, 11:46 AM
hamilton's Avatar
hamilton hamilton is offline
You might be able to help me with a few things (waiting membership approval on the brand appropriate forum).
Head stays are missing. I assume cracked. Revised parts for 2010+ - more expensive but probably worth it.
Pipe fitment. She's tight past the shock res. Updated canister for 2010. FMF shows fitment for 2010-2012 but no pipes for 2009. Any idea if the 2010 will bolt up OK?
I ran the 06 up fmf pipe, but liked the stock pipe better.
Fit some rubber between the stinger and shock res.
There was a update on head stays and power valves.
The top end held up good when using 32-1 mix.
Don't know if you have much time on 125's, I would get a feel for it before dumping much cash into it.
15 GASGAS EC 250
19 Sherco SE 125R
Old 06-08-2017, 04:19 PM
Originally Posted by arminhammer View Post
I think I still have some parts laying around if you are interested. I know I have a Rekluse, Leo Silencer and pretty sure I have the newer head stay brackets. Probably more.
Cheers! I was thinking of replacing the silencer and definitely need to source up head stay brackets.
I have the OEM plastic skid plate which will be OK for my purposes.
Like the idea above re painting the stock can. Will try and straighten it a bit first.
What did the replacement shock set you back?
Any benefit with the updates PV?
I can't say I've spent much time on a 125 at all. I know it'll frustrate me endlessly at times.. but I also have no issues hanging off a throttle and using the clutch!
50mm CC zokes up front on her. Just going to ride em before worrying about revalving etc.
Old 06-09-2017, 12:00 PM
Darkside Darkside is offline
If you decide to keep her. A guy on the cafehusky forum makes an awesome 165 kit
2006 GasGas EC300 2011 KTM 300XC
Old 06-09-2017, 08:56 PM
I've helped a mate bolt up a WB165 to his 13 WR. Modified SX pipe. Nice kit for sure, but not really something I'm interested in. If I want more powaaah I have modified 250cc donks here for the gassers, and if I want more grunt I'll throw the spare 300 jug on one of them!
The Husky represents a real budget bike! A little screamer. Something light which will force me to further refine my clutch and throttle control. Given the light flywheel on the CR and the smaller displacement it should indeed do that! I'm interested to see how the suspension will feel.
Old 06-09-2017, 09:04 PM
Stock springs are .42 and 5.0 good for 65-75kg rider. I'm 73kgs without gear, so she'll be sprung on the softer side for sure.
In comparison I run .45kg/mm fork springs on my Gasser with a 5.2-5.4kg/mm shock spring (have tried both).
The valving on a CR should be a bit firmer, so could work well together for banging through the bush.. or it could ride down a bit too far in the stroke and beat the crud out of me. We'll see!
Old 07-26-2017, 08:06 PM
She's coming along!!
2009 Husky 300 rear wheel crossover? sam Enduro Chassis & Body 0 01-15-2015 06:34 PM
looking for gasser husky tm 250 supet clean to trade up or down my 2013 husky 144 fletchman45 "Wanted to Buy" & "Want To Trade" 0 03-14-2014 05:11 PM
2007 Honda CR125 GMP All Other Bikes... 20 02-28-2013 04:01 PM
2008 Husqvarna CR125 MattR All Other Bikes... 17 04-27-2010 03:54 AM
In Theory; GG MC125 pipe on a CR125 Bearman Enduro Engine - 2 stroke 0 04-10-2008 02:43 AM
