Old 03-17-2015, 05:42 AM
Barbs Barbs is offline
Default 2015 EC300 questions.
Hi all. First time poster here and loving the forum.
I have recently got myself a new EC300 and have now put About 400km on it. After about 80 odd km of riding I put in a NEDJ needle #2 clip, left the 175 main and air screw around 2.5 turns. It rocks and plug checks all look good so far. I'm seriously loving the bike!
What I would like to know is do the gearboxes usually leave metallic residue on the sump plug? First oil change at 200km the plug was covered in fine metallic residue maybe 2-3mm thick all over the magnet, next change at 400 km still produced residue but only half as much. I'm hoping the residue is due to wearing in the engine.
Next question is regarding chain tension. When riding I can hear what sounds to me like chain slap or rattle. I have adjusted the chain as per the manual (35-60mm at the rear of the chain slider) but I'm concerned that it is too tight. When I compress the suspension the chain pulls tight and I'm worried it could be loading the gearbox bearings too much? At the moment the chain is looser than the manual specifies but I hear a chain rattle sound when the suspension is compressing. Is chain rattle a common thing on these bikes?
Thanks in advance.
Mark
Old 03-17-2015, 06:22 AM
A bit of build up on the transmission bolt is normal (in the early changes). It will reduce with time.
Best method to determine the chain tension is to pull the shock and run the swingarm through its stroke up. Find the tightest part and leave some play. Then measure from a point and record for memory. I just go by feel, but do run on the looser side and get a bit of slapping under light loads, high gears.
Old 03-17-2015, 06:27 AM
Thanks Jakobi,
That is exactly what I am planning to do. Hopefully I can find the issue with this slapping. It is really bugging me.
Old 03-17-2015, 06:43 AM
shang shang is offline
My last three bikes were KX450's which are notorious for chain noise and slider/guide wear. I've actually grown to like a bit of chain noise. I like the clacking sound when dropping to flat from a ledge or rock. But I run on the loose side as well.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 03-17-2015, 07:23 AM
I am going from a KTM250sx to a EC300 and the sound is doing my head I'm riding sometimes. As long as its not doing damage ill get used to it.
Old 03-17-2015, 10:14 AM
Neil E. Neil E. is offline
If the noise really bugs you, put a strip of 3mm thick closed cell foam tape under the chain slider. The noise is a result of chain slap on top of the swing arm.
2011 EC250E
Old 03-17-2015, 04:41 PM
Roger that! Or turn the throttle!
I only really notice it occassionally during transport sections where I'm sitting in 6th at around 50-60km. Never while riding. My old Yamaha 250F used to make heaps more noise, and the fix was the same as above (adhesive strip).
Old 03-18-2015, 01:31 AM
gg3's Avatar
gg3 gg3 is offline
Mine had metal filings on the sump magnet on first oil change.Second change pretty clean.The chain slap can be annoying but better a little loose than too tight.
Clutch questions. '05 EC300 CampX Enduro Engine - 2 stroke 13 06-20-2014 12:24 PM
ec300 broken clevis questions jt633 Enduro Suspension 2 06-08-2013 01:45 PM
(2) questions about my '06 EC300: brider Enduro Chassis & Body 2 03-28-2013 09:23 PM
EC300 vs 250f questions forgiven General Discussions & Announcements 18 01-19-2012 08:08 PM
Questions on a new bike? 2010 EC300 binsel General Discussions & Announcements 19 05-20-2011 08:58 AM
