Old 08-23-2022, 05:04 AM
Cox76y Cox76y is offline
Default A new problem with starter
Hi all,
I just replaced numerous components of my 2018 ec300 starting system as it stopped working. Its still not working. I can see where the problem is. The shaft that has the gear on it that makes contact with the Bendix is not spinning. The gear at the starter motor end is spinning but it is spinning freely of this shaft. I pressed the gear on there when replacing components and thought it was strange that it could spin separately from this shaft. I have attached the parts diagram, part number 16 is the shaft I am speaking about and the gear spinning is part 17. Does anyone know how to attach the gear to the shaft properly so the shaft spins with it?
thanks
JC
Old 08-23-2022, 04:03 PM
There are videos of folks with this problem. They welded the gear to the shaft.
https://www.youtube.com/watch?v=CXXjFw9ghDE
Old 08-24-2022, 01:23 AM
Thanks for the reply. I really can't believe they expected locktite to hold it together..
EC 300 2018 starter problem eralha Enduro Electrical & Wiring 74 10-08-2020 03:41 PM
Starter motor problem - fixed 5valve Enduro Electrical & Wiring 0 11-15-2016 02:38 PM
Who can rebuild a FSE 450 starter? Video with problem olderandyzer Enduro Engine 4 stroke (including EFI & Exhaust) 6 12-22-2014 04:23 PM
I bought a 2000 xc and keep finding problem after problem 675AZ Enduro Engine - 2 stroke 12 02-15-2013 07:25 PM
Starter clutch / gear problem iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 12 01-28-2011 02:45 PM
