Old 12-10-2022, 01:35 AM
5valve 5valve is offline
Need a special bearing puller for depressed bearings without exit hole.
Web search shows the cutout is supposed there, but polished area is not there, at least on the older models.
Will need to ask one of the 3 Marks, the Berg, the Haftka or the Moravek on that one.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 12-10-2022, 02:29 AM
(F5) (F5) is online now
All I have to say is the pictures are dreadful resolution.
Old 12-10-2022, 03:08 AM
Last one from ebay auction, but generally limited to 300kb file size.
The two Euro Marcs said machining is from factory.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 01-05-2023, 02:44 PM
Did you ever get this sorted?
Old 01-05-2023, 03:36 PM
Sth missing here? Older models had plastic washer between shift axle and case.
Most big particles were stuck under scorpion, making shifting impossible.
What torque values do you guys use on primary & clutch nut and magneto bolt. Booklet still says 40Nm for all, while in GG riders tech files this numbers are quite higher.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 01-05-2023, 05:32 PM
Yes, older bikes had a plastic washer and a snap ring/circlip on the end of the shift shaft. The newer bikes do not have them and I'm curious if this contributed to my 2018 chewing up a gear selector spring.
Did you find out where the aluminum particles came from?
The last time I had the cases apart I used the torque specs from the tech files, rather than the OEM numbers. The values for the nut on the clutch basket seemed OK, but the OEM flywheel and RHS crank nut torque specs seemed low.
Old 01-06-2023, 04:15 AM
I remember your spring snapping. Im putting engine together. Replaced all trans bearings, as one was notchy when installed, had to increase case hole slightly, it squeezed bearing too much. No clue where particles came from except if my mistake.
Also modding all linkage to accompany extra oring for errorless sealing.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 01-06-2023, 04:50 PM
Agreed on the o-rings for the linkage. Pivot works sells a good rebuild kit with o-rings.
https://www.amazon.com/Pivot-Works-E.../dp/B07SVMFVT2
Old 01-09-2023, 09:08 AM
My mistake. It looks like these still use seals.
Old 01-09-2023, 09:11 AM
For sure. I just crammed orings behind seals or behind washer plates for double protection and it works. Tested on previous bike.
EC 300 2008
EC 300 2018 GP
tenere 700
Best place to buy parts? DLap13 Enduro Engine - 2 stroke 6 09-01-2017 06:00 PM
GasGas in second Place hadfield4wd General Discussions & Announcements 3 05-03-2017 07:29 AM
Central PA place like HMT hadfield4wd NorthEast United States 1 04-04-2017 07:12 PM
Best place for OEM hardware? Koko General Discussions & Announcements 25 09-02-2012 11:02 AM
this may not be the correct place to ask, but... compmoto SouthEast United States 6 10-30-2010 02:10 PM
