Old 10-19-2019, 04:30 AM
slodrew slodrew is offline
Default ugh.. 2017 ec300 coolant in the oil and oil in the crankcase..
I recently bought this bike with a little over 50 hours on it and it runs great but somehow coolant is getting into the gearbox and a small amount of transmission oil found it's way into the crankcase.. should I pull the engine and split the cases? Can I reseal the cases without tearing everything apart? Any advice would be greatly appreciated..
Old 10-19-2019, 06:26 AM
Gasser Nate's Avatar
It may be transmission oil in the crankcase but it is probably residual two stroke oil. You might just have a leaking water pump seal or right hand inner crank gasket leak. Check there first.
Old 10-19-2019, 09:45 AM
gasgasman's Avatar
Water pump seals can be changed without pulling the engine.
Old 10-19-2019, 11:45 AM
that makes sense.. the red color threw me off but I'm running Amsoil Dominator so the red should be expected.. thanks!
Old 10-19-2019, 03:42 PM
gasgasman's Avatar
This workshop manual will apply to your bike.
https://www.dropbox.com/s/i93vw77r9k...anual.pdf?dl=0
Old 10-19-2019, 05:00 PM
rodent's Avatar
rodent rodent is offline
You can download manuals for each model back to 2002 on the GasGas.com homepage.
2017 ec300 buckmills93 Used Bikes 4 08-21-2018 03:52 PM
2017 ec300 nelly001 United Kingdom 2 02-01-2017 04:20 AM
Gasgas ec300 Crankcase pressure problem Stijn_M Enduro Engine - 2 stroke 23 09-09-2016 01:36 PM
Coolant in crankcase after rebuild Jacob 'Berg Enduro Engine - 2 stroke 27 03-06-2016 05:34 PM
Coolant in crankcase = no fun stainlesscycle Enduro Engine - 2 stroke 35 02-02-2012 09:59 AM
