Old 04-26-2016, 05:50 PM
nowheelies nowheelies is offline
I believe this meets the requirements for sparks:
1) Single exciter winding on the stator plus wires
2) Pulse trigger outside of the flywheel plus wires
3) CDI plus wires
4) Ignition coil plus wires
5) High tension lead plus spark plug
6) Grounds for the engine and coil etc.
(Ref: Neil E's post #26: http://www.gasgasrider.org/forum/showthread.php?t=21215)
Old 04-27-2016, 09:51 AM
Neil E. Neil E. is offline
Originally Posted by barossi73 View Post
Im not familiar with gg estart but the key 'on' position may/maynot also open supply to lighting circuit so if theres a short in lighting circuit...no power
This is not true unless the 2012 wiring is different than the 2011 wiring. I have also had the key switch apart so I can confirm it only has the functions that I mentioned above.
Nowheelies, I'm very busy at the moment, but I can look at the connections in more detail later on. Since the bike ran with the modified wiring, I would expect you have a bad ground or bad connection.
2011 EC250E
Old 04-27-2016, 06:25 PM
Don't sweat it too much! i got spark today so the wiring diagram is confirmed to work; kill switch blocks spark when it needs to, etc. in fact no wiring needs to go to the regulator to get spark.
Thanks for the help!
Jeff
Old 04-28-2016, 10:33 AM
Good to know it's working, did you figure out what the problem was?
2011 EC250E
Old 04-28-2016, 09:16 PM
TBH I don't know. I pulled the harness again and rechecked continuity, resistances, etc. On reassembly I got spark, I must not have had it connected properly or something was grounded that should have been.
Really appreciate the help,
Jeff
EC250R 2012 high RPM issue blamir Enduro Intake/Carburetion - 2 stroke 83 09-04-2014 04:01 PM
2012 300 e start issue schlitzy Enduro Electrical & Wiring 2 08-31-2013 03:07 PM
2012 ec250e blinkers?? Novascotiarider Enduro Electrical & Wiring 5 01-24-2013 01:42 AM
Rekluse for 2012 EC250E? robszombie Enduro Engine - 2 stroke 15 07-20-2012 03:52 PM
2012 300 issue bones150 Enduro Intake/Carburetion - 2 stroke 7 06-22-2012 12:29 AM
