Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 08-07-2017, 11:27 AM
Moto7man Moto7man is offline
New RK Oring chain. I an running a 13/51 Renthal sprocket set and I ordered a 120 link chain. I used a chain breaker to remove about 3 links and I used a chain press to install the new master link. The TM designworks chain guide is wide enough for the oring chain but the stock chain guide is too narrow.
I have a case saver ordered, it should be here on Wednesday. MSR folding shifter fit perfectly. Those are titanium footpegs from a YZF.
I used Oetikier clamps on the cooling hoses, they were very easy to install. I installed the power valve cover with a new oem Honda gasket and some cad bolts, then torqued to spec.
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-07-2017, 11:35 AM
Through the build I used a vet syringe with a brake line fitting to apply Redline assembly lube to each bolt, nut or landing to ensure my torque specs were accurate. The syringe makes application a breeze, keeps things tidy and avoids wasting the assembly lube. I think I could assembly three bikes with one bottle of lube using this method. The lube makes everything go much faster during assembly.
-Unknown Sardaukar
Old 08-07-2017, 11:37 AM
I installed a new Honda pipe mount with two cad bolts and a Honda spring washer to secure the pipe.
-Unknown Sardaukar
Old 08-07-2017, 11:47 AM
I filled the engine with synthetic transmission fluid and filled the radiators with coolant. I did a preliminary adjustment of the Recluse Auto Clutch with the Torque Drive Plate System. I still need to install the carb and pipe and tie up come loose ends, then we can begin the setup. And here is where I am so far.
-Unknown Sardaukar
Old 08-07-2017, 02:37 PM
Looking very nice!!
Old 08-07-2017, 06:41 PM
pscook's Avatar
pscook pscook is offline
Originally Posted by Moto7man View Post
YZ450F rear brake pedal fit great but the stock return spring won't clear the case, I need to find an alternative.
A good friend of mine uses a small block chevy valve spring on the clevis (between the clevis and the master cylinder) as a return spring. Maybe find a small diameter and firm compression spring to wind around the clevis bolt?
Phil
(New bike pending...)
Old 08-08-2017, 12:05 AM
Hey, I never thought about that, it's a great idea! Thanks very much!
-Unknown Sardaukar
Old 08-08-2017, 12:06 AM
Does anyone know if a a CCK needle and an R1369N needle are the same?
-Unknown Sardaukar
Old 08-08-2017, 06:20 AM
Zrt1200 Zrt1200 is offline
A CCK is a lot leaner from what Jets R US has posted. Its close to a CGK. Page down in the link.
https://jetsrus.com/a_jets_by_carbur...n_N427-48.html
Try this out as well....
http://www.kyajet.de/?lang=en
Old 08-08-2017, 09:26 AM
Pete406 Pete406 is offline
Fasst company makes a nice brake return spring! It mounts on the master.
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
