Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 03-02-2017, 10:19 AM
Moto7man Moto7man is offline
I got new side caps for the swingarm. The swingarm was powdercoated silver.
I also installed the rear brake hose guides with cad bolts.
I old brake pedal was a little beat up so I got a 2014 YZf 450 brake pedal and it bolted right up. I might need to trim the Yamaha bolt a bit with a dremel because it is close to the swingarm but is has good amount of clearance. I ordered a Yamaha master cylinder U clamp bc the YZF brake pedal is a little wider where it joins the master cylinder. Also, those footpegs are titanium and came off a 2009 YZ250. I used Yamaha pins and springs to mount them.
―Comedian Lewis Black
-Unknown Sardaukar
Old 03-02-2017, 10:25 AM
I am very happy with the backgrounds and numbers from Decal Works.
I also installed a new oem tank strap. I'm not sure if the orientation of the strap is correct. I installed the new upper seat mount washer with a cad plated bolt. I also installed a new oem fuel valve and oring, pics to follow.
-Unknown Sardaukar
Old 03-02-2017, 10:27 AM
I am going through a lot of Honda OEM parts, here is a shot of some of the empty bags.
-Unknown Sardaukar
Old 03-03-2017, 05:27 AM
Leo's Avatar
Leo Leo is offline
Wow! Had one 94 CR back there days!
Congratulations nice job
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 03-03-2017, 05:15 PM
Thanks very much!
-Unknown Sardaukar
Old 03-03-2017, 05:25 PM
Suspension from Works Enduro Rider
Shock, anodized black.
Shocks and forks
This is how she looks at the moment, ....we are getting there.....
-Unknown Sardaukar
Old 03-13-2017, 11:48 AM
I finished the rims, installed Tubliss inserts on the front and rear wheels with new metzeler tires. I put a Unicross on the front and Six Days on the rear. I got it off the stand and sat on it for the first time in 18 months!
-Unknown Sardaukar
Old 03-13-2017, 03:58 PM
Is there a special tool to remove the small round "grub"cover on the brake pad pin for the front brake caliper? Mine is seized up and I will put a torch on it but I wondered if there was a special tool to fit the groove, my impact driver fits the groove but it is just a little too wide
-Unknown Sardaukar
Old 03-21-2017, 10:37 PM
I finally got the little cover off and thankfully the brake pin wasn't seized and came right out.
-Unknown Sardaukar
Old 03-21-2017, 10:57 PM
I am trying to get the Honda finished and ride it a little before the 2018 Gassers get here. I mounted a "Braking" Wave rotor on the front and an EBC vented rotor on the rear. I finished bleeding the front brake and it works good. I hooked up the rear brake master cylinder linkage with the 2014 YZ450F brake pedal. I was able to use the stock Honda pin but I had to bend the Honda clevis. I had bought a New YZF clevis but it was a smaller size than the Honda master cylinder and I could not use it. The YZF pedal bolt cleared the swingarm but it was a little close.
I was going to install a Megura 314 throttle but I had trouble finding a throttle cable that I thought would work. I got a good deal on a Domino Throttle and I bought a nos Honda throttle cover that slipped right on without a problem.
-Unknown Sardaukar
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
