Old 01-26-2018, 10:36 AM
Neil E. Neil E. is offline
gman, can you post some pictures? I'm sure others are curious as to how you made it fit.
2011 EC250E
Old 01-31-2018, 01:59 AM
giov81 giov81 is offline
Originally Posted by gman View Post
Hi,
I just upgraded my e-start on the 2014 gas gas to the 2017 model. Mine made a hell of a noise when first using it and the motor was getting hot. If the bendix is too tight in the bushes in the engine case it will bind and won't have the inertia to "fly out". I removed the bendix, dabbed some light grease in the bush and its fine.
Incidentally - if anyone wants to know how to fit a 2017 e-start to a 2014 ec300 (i.e. replace the rubbish unit) without changing the crank case get in touch. I designed a spacer ring and have a drawing I can send of the part to be machined.
Regards,
Gary (UK)
Hi Gary, could you send it to me, my mail is giovannifiorita@gmail.com.
Thanks in advance
Old 09-23-2018, 10:52 PM
(F5)'s Avatar
(F5) (F5) is offline
Ok, a mates 2015 blew the bendix apart and cracked the main cover slightly. I got the cover welded by my weldy guy. A bit of gear tooth got jammed and caused the crack.
But the initial problem is this; the outer cover there is a plain drilling in ally that a steel shaft spins in unlubricated. As you can see it has ovalise, and pushing the shaft away got some angle and boom. Zoom in and you'll see.
So I've made a big to hold it straight and will bore, fit a thin 8mm x 6mm ID bush. It's pretty thin but with care should be fine.
Part 2. Bike shop he bought it from experiments with blocking the drain hole in lower cover and running a small amount of fork oil in there, enough of a puddle to get dragged around by flywheel and lubricate things. We'll be trying that.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-23-2018, 10:58 PM
(F5)'s Avatar
That's just some scrap ally spacers and 5mm screws with tapped holes in plate. Needs to be held flat so I can run an 8mm mill bit into it.
Here's the bendix. Not pretty. Or cheap.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
2015 Gasgas ec 300 e-start seitz331 Used Bikes 3 09-17-2017 06:25 AM
2015 XC300 e start tzsuzuki Used Bikes 3 07-06-2017 09:02 PM
2015 E-start burned Dj_Zorba Enduro Engine - 2 stroke 24 03-29-2016 05:50 PM
2015 GasGas EC300 E-start wilmington_powersports Used Bikes 2 12-03-2015 10:51 AM
EC300 Idle Revisited. Ud_luz Enduro Intake/Carburetion - 2 stroke 35 01-07-2011 07:39 PM
