Old 11-20-2012, 03:35 PM
Sr412 Sr412 is offline
Default 1999 ec250
I'm new on this forum sorry if this is a repost but couldn't find what I wanted with the search.
Firstly I'm going to rebuild the engine next week mainly for peace of mind ready for the winters green laning.
The biggest reason for prompting this is I have a fair bit of end float on my crank not up and down like when mains are worn but more in and out. The flywheel pulls in and out about 3mm. I'm certain this isn't normal!!
And finally where is the best and cheapest place for rebuild parts?
Piston
Conrod kit (cr250?)
Gasket set?
All bearings and seals will come via my trade supplier I use for bearings at work.
Thanks in advance
Old 11-20-2012, 10:20 PM
Rick's Avatar
Rick Rick is offline
My 99 EC 200 is the same way. It has end play,but no up and down play. There was a thread a few years back on this subject. If i remember correctly it is due to a different type of crank bearings..... Mine have been like this for years...and no issues at all.
As for parts GoFasters or any of the dealers can get your parts.
Good luck and welcome.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 11-20-2012, 10:27 PM
(F5)'s Avatar
(F5) (F5) is offline
Piston
Conrod kit (cr250?)
Gasket set?
Thanks in advance
I'm pretty sure no one has posted before about rebuilding your bike, but it is a 99 so maybe a previous owner could have, can't rule it out for certain
Woosner pistons seem to be good quality & cheap from many sources, but no idea where you are based. So I'll assume you are also from New Zealand & can recommend where I bought mine from.
1999 EC250/300 gearing c-152 Enduro Engine - 2 stroke 0 04-07-2008 11:04 AM
1999 ec250 info toad Enduro Engine - 2 stroke 2 01-17-2008 07:03 AM
