Old 03-31-2019, 08:14 AM
Jdstep Jdstep is offline
Exclamation 2001 Gasgas EC 300 running issues. Help needed.
Hi all
I recently got a 2001 GG EC 300
It's idles for about 3 seconds then the idle drops and the bike dies. This happens at all engine temps.
I have got a JD jetting kit, currently running red needle on middle clip. 178 main and 38 pilot. Air screw is at 2 turns out. Idle screw seems to make no difference until it's wound almost all the way in.
I set the float level as per other threads and found that it still leaks upright unless it's set super low. To the point where the needle closes when the floats at 35 ish degrees from the carb body.
The bike is also using A LOT of fuel even when not riding at high rpm.
I also find the bike is very spluttery when at a constant throttle at any RPM
Carb has been thoroughly cleaned and reeds are all okay.
The top end is brand new and air filter is clean. There is also no air leaks in the system.
I removed the plug and will attach a pic for anyone that's good at reading plugs
Any help or advice would be greatly appreciated
Thanks
J
Last edited by Jdstep; 03-31-2019 at 08:21 AM. Reason: Missed info regarding idle and air screw
Old 03-31-2019, 12:58 PM
(F5) (F5) is online now
Buy a new float valve.
Old 03-31-2019, 12:59 PM
Sorry forgot to put in there. Carb has had complete rebuild including jet block o ring and the float needle.
Old 03-31-2019, 05:39 PM
I would make sure the float still floats! Does it have any holes in it when fully submerged in fuel? If you get a cotton bud with some metal polish on it and spin it up in a drill it can polish out any imperfections in the needles seat. I once had a hair of some sort stuck in the seat causing a brand new bike to piss fuel everywhere.
Old 04-01-2019, 09:47 PM
It could be leaking fuel past the needle and seat. Sometimes the brass seat gets worn or corroded which prevents sealing. You can polish it with a Q-tip and some tooth paste if you chuck the Q-tip in a drill.
Old 04-09-2019, 04:38 PM
Thanks for the replies.
Float needle seat has worn out. The slide is also in a bad way. Have since fitted a lectron and all issues are fixed.
Recommend the lectron highly
Sent from my Land Rover Explore using Tapatalk
Old 04-10-2019, 09:32 PM
Stepsidebowtie Stepsidebowtie is offline
You have a picture of the carb on the bike? Did it go in with any modifications?
300 running issues Jon250 Enduro Intake/Carburetion - 2 stroke 37 09-15-2013 05:10 PM
Ec250 running issues jimgsxr86 Enduro Engine - 2 stroke 9 05-03-2013 05:52 PM
2001 300 EC - More Snap Needed krazy Enduro Engine - 2 stroke 12 09-13-2008 09:50 PM
2001 EC 250 plug issues HELP Silver Enduro Engine - 2 stroke 14 08-08-2007 03:38 PM
