Old 04-20-2022, 10:52 AM
Cstewa37 Cstewa37 is offline
Default 2011 EC Wiring Route
Hi all,
Could anyone share some photos of the wiring route on a 2011 EC? Trying to work the wiring around where the fuel tank sits, but also where the main loom joins the lightswitch and headlight etc.
Cheers
Chris
Old 04-20-2022, 12:10 PM
Neil E. Neil E. is offline
Not exactly stock wiring, but should give you a general idea.
Old 04-20-2022, 12:39 PM
Thanks Neil, that's a great start! You've got A LOT more wires at the headlight area than mine, maybe because mine is non estart and has no turn signals?
Any chance you have a photo of the wiring from the stator going to the CDI and how it loops around the tank? My loom (a new GG replacement one) seems really short.
Cheers
Chris
Old 04-21-2022, 11:45 AM
The extra wiring is for a Trailtech Voyager and a pair of LED lights with a dimmer module. The pictures show the stator wiring going up along the clutch cable, turning back and going across behind the top shock mount. Then making a sharp turn through the right side wiring channel in the airbox. The CDI wiring actually goes through first so it is hidden behind the other wiring. The same is true when it crosses behind the shock; it is below the vent hoses.
Old 04-21-2022, 01:19 PM
Awesome that's exactly what I need, thanks dude!!!
Chris
Old 06-17-2022, 10:36 AM
Kolby198 Kolby198 is offline
This is helpful for me too. I not have the same setup as you but have been trying to redo a botched wiring job on a 2011 ec250. I cant for the life of me figure it out. Only last week did i realize there is a high and low beam switch that missing.
Old 06-18-2022, 12:26 AM
Not to mention the Medium beam switch on the unit itself.
Did you look?
In search of: EC 300 2010 - 2011 wiring loom mmarco78 Parts 0 06-25-2020 10:39 AM
Help on how to route 400 fse throttle body hoses jason r Enduro Engine 4 stroke (including EFI & Exhaust) 0 05-01-2020 02:20 PM
Route Sheet Holder - Designed to last lneil06 Parts 6 06-19-2017 02:19 PM
2011 EC250 Wiring harness wanted Motomecc Parts 0 11-14-2016 04:26 PM
2011 Ec250 wiring questions toolmaker General Discussions & Announcements 0 01-04-2011 07:38 AM
