Old 04-19-2009, 10:03 AM
101racing 101racing is offline
Default Putting in new rings
What do u guys do when u rering the piston. We did scotch brite on 07 ktm 300 cylinder or do you hone with a special stone?
Thanks
Old 04-19-2009, 04:57 PM
I use a 3" ball type hone.
Old 04-19-2009, 08:00 PM
Hope like hell the rings fit!!
My first top end ever .. on my 06 300 really only needed new rings ... unfortunately the rings shipped did not work in the stock piston .. it turned into a little mystery as the part number was correct and the rings inside the package were correct. They just did not like the stock piston ..I had to get a new piston and rings.
Old 04-19-2009, 08:23 PM
2 strokes 4 life's Avatar
Well some people just use scotch bright but really that Nikas lining is supper strong.
To do any realy good just take it to a shop and have them use a diamond hone. It should cost $30 at max then you know the bore is straight and what not.
2012 Ktm 300xc
2001 Gasgas EC300
Old 04-19-2009, 08:42 PM
noobi's Avatar
noobi noobi is offline
i thought your're not supposed to hone nikasil bores?
Old 04-19-2009, 09:06 PM
Brian VT Brian VT is offline
It's pretty tough. Scotch-Brite ain't gonna touch it. If you have any aluminum on it, from a melt-down, then apply muriatic acid with a Q-tip to remove it. Might have to sand a bit too. When Q-tip is clean you should be set (no more aluminum). Better to get diamond honed, as stated.
Old 04-20-2009, 08:36 AM
Eric K Eric K is offline
Check and set the ring end gap to spec.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 04-20-2009, 10:58 AM
Default Scotch brite
Did u (gasgas man) get 3 in ball hone for nikasil application and what grit did you use. I dont know if i can get diamond hone or not but i will see what my dad thinks.
Thanks for all the replies
Old 04-20-2009, 02:02 PM
The ball hone I used is just a standard 3" version.
I don't think they make different grit hones.
The idea is just to break the glaze off.
Usually, 3 times up and down will do the job. You want a 45 degree cross hatch pattern when you're done.
Use WD40 to lube it while honing.
Old 04-20-2009, 05:09 PM
You wont be able to afford a diamond hone. The 3 ball does nothing on these cylinders because the plating is much too hard. Plus you run the risk of making un-square. Just take it to a machine shop or bike shop.
2012 Ktm 300xc
2001 Gasgas EC300
Head O rings Highwayman Enduro Engine - 2 stroke 8 02-04-2010 08:43 PM
O-rings. Ud_luz Enduro Engine - 2 stroke 7 11-23-2009 06:14 PM
Rings steve Enduro Engine - 2 stroke 2 03-10-2008 02:36 AM
Athena rings PEB Enduro Engine - 2 stroke 7 02-28-2008 03:03 PM
Piston and rings EC 300 brains Enduro Engine - 2 stroke 1 08-22-2007 12:11 AM
