Old 12-11-2019, 04:06 AM
Nicktamps Nicktamps is offline
Default Vibration
Hi all. Bought a 2015 ec250 bout a month ago. It vibrates a lot. My mate got a 300 same year and it doesn't
vibrate half as much. Changedd the o rings in the exhaust and the springs. Done bolt check. Changed rear wheel bearings. Anything I can check?
Cheers
Nick
Old 12-11-2019, 07:35 AM
Pygmygod Pygmygod is offline
2-stroke engine without a counter-balancer will vibrate.
Check if you both have the same handlebars, maybe he has aftermarket ones with some kind of anti-vibe collar/adaptor?
Or maybe he has thick spongy bar grips and yours are worn thin?
I'm new to 2-strokes, but perhaps you rev yours more and he lugs his around? Maybe this is adding less noticeable vibrations due to less rpm?
Old 12-11-2019, 10:42 AM
Na mate I've ridden his and his has a lot less vibration. My grips are brand new. It just seems like there's something wrong with mine causing it
Old 12-11-2019, 11:39 AM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Default vibration
Double check all your engine mount locations . Esp rear swingarm
Old 12-11-2019, 08:43 PM
Your crankshaft may be slightly out of alignment.
Old 12-12-2019, 07:41 AM
I have seen a GG where one of the head stays was loose. It was horrible...
Did you check them? Also take off your bash plate if its made from aluminum and try again...
Old 12-13-2019, 02:01 AM
I would bet it would be this too. I put together a motor for a mate and carefully trued the crank after the crank stuffer bolts fell out and it was the smoothest 300 gasser I?ve ridden. I think the factory specs are a little on the wide side. I aim for less than a thou run out.
08 ec 300 vibration fatdaddy Enduro Engine - 2 stroke 2 02-24-2012 10:58 AM
vibration fix. stainlesscycle Enduro Engine - 2 stroke 2 02-22-2012 07:49 AM
vibration peanutsracing1 Enduro Chassis & Body 3 04-19-2011 08:55 PM
Vibration mikeh Enduro Engine - 2 stroke 2 04-21-2010 04:18 PM
foot peg vibration MIKEWA Enduro Chassis & Body 3 03-19-2007 08:42 PM
