Needles... what's the difference and where to buy?
Hi guys me again...
My bike was starting to run a bit "iffy" I am no expert but I have some good solid friends around me who guide my hand. After a bit of research I decided to drop my pilot jet from a 45 to a 40. After fitting it. The bike started to splutter terribly at about 1/4 throttle and struggled to pull into the band. I swapped the jet back to the 45. Put the carb back on. Bike was running like a 3 legged dog. I called for back up. Cleaned the carb put the standard jets in. She still ran like a Bitch. So I moved on to the stator. It was fried. 5 jet Black loose coils one had split completely. Ordered a new stator fitted that. Bike still ran like a 3 legged dog. Aaaarrrg Took the carb apart again. Checked the float hight.... Then, at 11pm my buddy checked the needle. It was in firmly. Very firmly. The top adjuster had bent and was wedged against the clip holding it in. Appx 5 10mm too high!! No wonder it was over fuelling like a pig. So after further research and a lot of reading on here. I find there are so many different needs out there? I believe mine is an n1ef but what is the difference? Am I best off sticking to the standard needle on clip 3 and adjusting the jet according to the weather? Any suggestions on the best needle for 48' running a 38 idle a 178 main sportsman/ novice rider on a gas gas ec 250 Also where do you buy them from? (I'm in the uk)
GasGas Not Ass Gas.... No more KTM EXC'uses... www.scunnybikers.com @Ktmandy |
Try "Allen's Performance" in the UK. They should be able to help you with Keihin PWK parts and tuning.
It's a n3cj Andy , don't call Allen's performance and ask for that as they will tell you it's only 3 letters , that's what I was told
Is it just me, or unless you have an exact hour, day, month and year of bike manufacture, your National Insurance number, along with your inner thigh measurement and your wifes breast size: are the most unhelpful people on this Earth ? I understand they dont want to send the wrong part (And this seems to be what it all revelves around) but they are the 'experts' after-all ! Im the most impatient human being on this Earth, but the last time i ordered some Kehein jets for a WR250 i ordered from the US rather than than 'them'. This chap is EXTREMELY helpful to, and post is just a couple of days to the UK: http://www.frankmxparts.com/
Regards Shuv - 2006 EC 250 |
I like smooth power delivery NEDF Suzuki needle part no (13383-37FHO) I think, 42pj, 172mj try that see what you think. Get needle from KAIS .Hope this helps.
Cheers guys lots of helpful suggestions. I've been checking the net and online stores... your right about them being hard to find.
I think I'm now looking for 1 step up from the standard n1ef and going for an n1eg which is off an 1999 rm 250 or an n3wk as it's meant to smooth out the curve. And let the 250 tick over easier. I just need to find one now
Whats the difference | joedirt | General Discussions & Announcements | 10 | 01-16-2012 08:21 PM |
300 and 300 6 days engine difference | BELLY FROM OZ | Enduro Engine - 2 stroke | 9 | 08-03-2011 10:11 PM |
Difference between LTR needles? | SWMS | Enduro Intake/Carburetion - 2 stroke | 0 | 06-28-2011 12:41 AM |
2k-2 2k-3 ... difference? | swazi_matt | Enduro Electrical & Wiring | 4 | 10-20-2010 04:52 AM |
Engine difference? | darren | Enduro Engine - 2 stroke | 3 | 01-08-2009 02:25 PM |
