300 and 300 6 days engine difference
Hey there,
Any one know exactly what the differences are between the engines of the 2011 ec 300 and the 2011 ec 300 6 days. I understand that the ec300 is a lot tamer than the 6 day model and would like to kow exactly what they did to the 6 days to make it so much more potent. What are the jetting differences (sizes, numbers etc) Needle differences maybe flywheel weight and squish and so on. |
I thought they were the same? I rode last years (2010) ec300 and sixdays and the sixdays didn't seem anymore gnarly. I havnt gotten to ride this years ec but I have rode the sixdays and I don't think it's any more gnarly than last years ec. Just my 2 cents
trevor |
Nada. The Six Days does sport a stainless steel pipe however.
The 6D comes with different head/inserts, correct?
BTW, I couldn't really tell a difference between the base EC and 6D. I *could* tell the difference between the 300 and my LTR/squish/carb-modded 2005 at 7,000 feet (with 52T rear sprocket). The 300 pulled up grades in one or even two gears high and pulled strongly. My 250 liked the right gear. However, now that I've just done a top-end, my 250 is back pumpin' it up. |
I can.t find any differencies between 6d, racing or regular GG motor... Differncies are suspension, skidplate and "bling bling" parts...
There is no such thing as bad weather! Only riding gear is improper or insufficient When it hurts you know you're allive! Gas Gas EC 300 Factory Racing 2012 - Ohlins TTX both front and rear - Rekluse Core EXP 2.0 + Rekluse clutch basket - Scalvini full exhaust system - S3 Head - Trusty adjustable PV cover That was ultimate setup for me... Now trying something else for a while... |
no the sixdays does not come with a different head or inserts. thats the S3 head on the cervantes and the nambo's
trevor |
I always wondered this. Back back back in the day I believe some of the Race models shipped with a lighter flywheel/stator. Pretty sure they're all the same same now.
Does the electric starter add anymore flywheel effect? |
For a 2K3 setup, the only added weight is the very thin ring gear attached to the flywheel. I doubt you could tell the difference. You would notice the extra 12 lbs of battery and starter first.
2011 EC250E |
Im not sure about the 6 days but i believe the race comes without the carb spacer to give it more hit.
Thanks for clearing up the starter question
Re carb spacer: I assume you mean the reed spacer? I have a limited edition bike (1 of 20) that was brought into aus and sold as a 'Euro'. Basically its a 2010 Race with some stickers that say Euro on it. It has the reed block spacer in place also. |
Difference between LTR needles? | SWMS | Enduro Intake/Carburetion - 2 stroke | 0 | 06-28-2011 12:41 AM |
2k-2 2k-3 ... difference? | swazi_matt | Enduro Electrical & Wiring | 4 | 10-20-2010 04:52 AM |
Difference between the 2010 models? | usedtobefast | General Discussions & Announcements | 9 | 12-27-2009 07:58 AM |
Engine difference? | darren | Enduro Engine - 2 stroke | 3 | 01-08-2009 02:25 PM |
Compression distance difference on pistons | Adrian | Enduro Engine - 2 stroke | 6 | 05-17-2007 06:50 PM |
