Old 03-03-2013, 04:51 PM
jt633 jt633 is offline
Default 2004 ec300 died newbie helpp!!!!!
plase help! im new to electrical had a bad day today, to begin my ride today my gasgas fired right up as usual and after warm up I took it for a cruise down the alley about half way it bogged as though it wasn't sparking so I unplugged headlight after seeing bare wires I taped them both separate and bike ran fine rode approx. 2 hours in wet mud conditions and laid it down on right side (pipe side) and bike stalled I figured it would picked it up would not start it fired one time and it was a bog reved a little bit and bogged out again new plug no spark any ideas? thinkin I have a bad ignition or I have a short somewhere? wish the damn thing had blown up I could fix that!!!! a little bummed I haven't been able to run a tank of gas through it since I bought it2 weeks ago
Old 03-05-2013, 04:00 AM
olderandyzer's Avatar
olderandyzer olderandyzer is offline
sounds like a short. Check the wiring with an ohmmeter. As you said it bogged with the headlight on.
It could also be the stator went bad. Look inside the ignition cover. Make sure that is dry. Spray some WD40, or better yet, some CRC electrical cleaner on there. Make sure there are no loose wires or frayed wires inside.
Also check the spark plug cap. Some bikes have a resistor cap and that can cause a problem also.
older and yzer
2004 ec300 fork coachtech Enduro Suspension 6 08-29-2012 12:13 PM
Newbie bought 2004 EC250 - need help with parts stuckinatree Enduro Engine - 2 stroke 13 11-09-2010 09:14 AM
2004 ec300 elemetal General Discussions & Announcements 2 11-04-2010 09:56 PM
What is it with Jetting - 2004 EC300 bigkatuna Enduro Intake/Carburetion - 2 stroke 9 11-28-2007 10:28 AM
