Old 09-29-2006, 06:09 PM
d251man d251man is offline
Default lowering links
Anyone ever use the lowering links that are available . It is supposed to lower the suspension and deliver a lower seat height. It is supposed to drop it an inch or so.
Old 09-29-2006, 08:16 PM
Dave Dave is offline
I made some for our son's KX100. They work as advertised.
Old 09-30-2006, 08:21 AM
LTRace's Avatar
LTRace LTRace is offline
We offer 3 different pull rod sets to lower or raise the seat height. We offer a 120 mm to raise the rear 10 mm. or 400". For lowering, our 124 mm will drop your seat height by 10 mm or .400" Our 126 mm will drop your seat height by 20 mm or .800"
If your bike is equipped with the correct shock spring for your weight, using the 126 mm may require you to spring up to the next rate. The 124 mm and 120 mm only require a pre load adjustment. This is considering the spring is correct for you.
In addition to changing the seat height with the pull rods, you are able to change the bikes handling and combine different fork heights in the triple clamps for your desired results.
You can give us a call if you would like more details or advice for your specific needs.
Les
www.lt-racing.com
Port Orchard, WA USA
Lowering Rear Brake Pedal Height? 2whlrcr Enduro Chassis & Body 9 08-29-2010 06:17 PM
lowering bike Silver Enduro Suspension 6 03-16-2010 10:35 AM
Lowering Pegs Dingo Enduro Chassis & Body 3 01-14-2009 10:25 AM
Kamikazi Stand and Lowering links TeeJay Enduro Chassis & Body 7 10-13-2006 01:17 PM
