Old 11-27-2013, 01:30 PM
Lukemoto
Guest
Posts: n/a
Default 2012 EC 300, Standard jetting/ N1EG needle?
Hi all from here in the uk, just flicking through the manual and some paperwork i got with the bike and have seen that my bike has been "tuned" but all thats changed is the needle which is a N1EG? Is this any good? Has this needle made the fuel mixture richer? I also see in the manual there is some carb settings for Competition use, are these any good? anyone tried them? I don't really like the bike running too lean so any help would be good! Also the idle "hangs" when you rev it at idle? The throttle cable is fine and no air leaks that i can find!
Old 11-27-2013, 02:39 PM
Needle is no good. Slide is probably raised too high (spring coil bound). Check the pilot and main too, and then start searching. Loads of threads. Search keywords such as NEDJ NEDW NECJ N3CJ N3EW. Should give you a days reading.
Standard Jetting and plug? uwynn77 Enduro Engine - 2 stroke 2 06-23-2013 09:51 PM
standard jetting info please uwynn77 Enduro Intake/Carburetion - 2 stroke 5 11-27-2012 04:44 AM
n1eg in jd jetting database.... stainlesscycle Enduro Intake/Carburetion - 2 stroke 8 10-03-2011 01:07 PM
Standard Jetting macho comacho Enduro Intake/Carburetion - 2 stroke 3 10-13-2009 12:15 PM
What is the standard (emissions) jetting as new ? stay_upright Enduro Engine - 2 stroke 11 07-08-2008 11:18 AM
